1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ASYN/devGPIB/GPIBCVTIO problem
To: John Dobbins <[email protected]>
Cc: [email protected]
Date: Sun, 05 Feb 2006 08:15:27 -0600
John, regarding...
John Dobbins wrote:
Dear All,
I am confused about what is happening with an Analog In record connected to an ASYN device. In particular this is a devGPIB device with a command of type GPIBCVTIO.
I have created the custom convert routine for this devGPIB GPIBCVTIO command and it appears to work, i.e. I have connected it to an Analog In record and if from the EPICS command line I force the record to process (dbpf aiRecord.PROC 1) and then examine the record's value (dbpr aiRecord) it has correctly retrieved the value from hardware.
However, I next did the following:
I added a dfanout record and an Analog Out record. All three records are passive. I set the DOL of the dfanout record to be the "aiRecord.VAL PP" and OUTA of the dfanout record to be the "aoRecord.VAL PP".
aiRecord -> dfanoutRecord -> aoRecord
I see this behavior when I make dfanoutRecord process:
1) aiRecord processes
3) ao record processes writing the stale value, i.e. the value the aiRecord had before it processed
Note, from ASYN diagnostic output I see #1 happen and then #3 happen.
I infer that in between these the following happened
2) dfanoutRecord retrieved stale data from aiRecord and passed it to aoRecord
So the question is why is the dfanout record retrieving the stale value? It seems it must be that the value is retrieved before the aiRecord is actually done processing.
The last lines of my convert routine are:
       precord->val = floatData;
       precord->udf = 0;
      return 0;
After which the code in devGPIB is responsible for setting PACT = 0.
Have I gone wrong somewhere? Any advice appreciated.
info: EPICS 3.14.7, ASYN 4.2.1, Linux IOC
That's the way it's supposed to work. The only thing that waits for asynchronous processing is the forward link of the record whose device support is asynchronous. This is not peculiar to ASYN; it's a general feature of asynchronous processing. A PP input link starts processing that will eventually return the new value, but just takes whatever value is there. Otherwise it would hold up all the other records being processed by the same task.
John Dobbins wrote:
> A follow up note:
> I changed dfanoutRecord DOL to be "aiRecord.VAL NPP" and then used a seq
> record to first process aiRecord and then after a delay process
> dfanoutRecord.
> This fixes the bad behavior which is consistent with the theory that
> dfanout was grabbing aiRecord.VAL too soon.
> Also note that if I replace dfanout with an ao, DTYP = "Soft Channel" I
> see the same behavior, so this problem is not specific to dfanout.
You might also have the forward link of the AI record process the dFanout
record.  Then you would not have to guess how long a delay to use.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Re: ASYN/devGPIB/GPIBCVTIO problem Benjamin Franksen
Prev: ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Next: Re: ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
