Hello!
I want to use Archive Data Server.My OS is linux redhat 9 with epics base
3.14.7 and Channelarchive2.6.0.
According to the manual.pdf.I create directory
/var/www/html/archive/cgi,and copied
ChannalArchiver/XMLRPCServer/O.linux-x86/ArchiveDataServer
/var/www/cgi-bin/xmlrpc/ArchiveDataServer.cgi,and ChannalArchiver's example
serverconfig.xml,serverconfig.dtd to /var/www/cgi-bin/xmlrpc/,and add
following to httpd.conf:
<Directory "/var/www/html/archive">
Order Allow,Deny
Allow from from All
</Directory>
<Directory "/var/www/html/archive/cgi">
SetEnv "EPICS_TS_MIN_WEST" "-480"
SetEnv "LD_LIBRARY_PATH"
"/usr/local/lib:/home/liushu/epicsinstall/base3.14.7/base/lib/linux-x86:/home/liushu/epicsinstall/base3.14.7/extensions/lib/linux-x86"
SetEnv "SERVERCONFIG" "/var/www/cgi-bin/xmlrpc/serverconfig.xml"
PerlHandler Apache::Registry
PerlSendHeader On
Options ExecCGI
</Directory>
Then I restart httpd by /etc/rc.d/init.d/httpd restart.I run
ArchiveDataClient.pl -u
http://192.168.20.155/cgi-bin/xmlrpc/ArchiveDataServer.cgi -i
I got these output:
not well-formed (invalid token) at line 1, column 0, byte 0 at
/usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi/XML/Parser.pm line
185
Is there anyone know what's wrong?
And I have some questions:As I know that ArchiveEngine is web server too,so
I want to know if I start ArchiveEngine I don't need to start httpd,right?And
if I start httpd I don't need to start ArchiveEngine either,right?Or if I use
ArchiveDataServer,which one I need,ArchiveEngine or httpd running?
Thank you very much!
Best regards
Liushu
- Re: ArchiveDataServer errors Kay-Uwe Kasemir
building EPICS ArchiveViewer Jiro Fujita
Re: ChannelArchiver build error D. Peter Siddons
<2006>
Re: building EPICS ArchiveViewer Jiro Fujita
<2006>
