1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: labCA crashes with bad PV
To: "Allison, Stephanie" <[email protected]>
Cc: Dennis Nicklaus <[email protected]>, [email protected]
Date: Mon, 13 Feb 2006 11:47:31 -0800
Note that Steph is using Matlab  7.1 (aka 14.3) which doesn't seem
to suffer from the problem (14 pre-releases, 14, 14.1 and 14.2 do!).
The problem I've seen is really a matlab/installation rather
than a labca problem. I can reproduce it with the simple mex file
#include <mex.h>
void mexFunction(int nlhs, mxArray *plhs[], int nrhs, const mxArray *prhs[])
        mexErrMsgTxt("BLAH");
The workaround is (see ReleaseNotes)
setenv LD_PRELOAD /lib/libgcc_s.so.1
prior to launching matlab. Depending on your linux distro and
exact matlab version YMMV.
HTH
-- Till
PS: For folks using labca on win32: there is a problem with the newest
version of matlab (only first 'lcaGet' works, subsequent ones will
"immediately timeout", i.e., indicate a timeout without even waiting).
The problem has been solved but I didn't have the time time to package
up a release yet. Contact me for a patch or disable Ctrl-C handling
and rebuild labca_2_0 (win32 affected only).
Allison, Stephanie wrote:
Hi Dennis,
> lcaGet ('garbage')
hangs for a minute or two, then takes down matlab.
Hitting control-c during the timeout also crashes matlab.
Hmm. I do the same test on a linux box (2.4.21-37.0.1.ELsmp #1 SMP i686 athlon i386 GNU/Linux) running epics 3.14.8.1+strtod patch with no problem (see below). Can you provide more information like what version of epics are you using?
BTW, I like labCA since it lets me set retry count and CA timeout. The older version of MCA that we have here doesn't allow it. Plus Till sits next door.
matlab -nojvm
                              < M A T L A B >
                  Copyright 1984-2005 The MathWorks, Inc.
                   Version 7.1.0.183 (R14) Service Pack 3
                              August 02, 2005
To get started, type one of these: helpwin, helpdesk, or demo.
For product information, visit www.mathworks.com.
lcaGet('garbage')
Initializing labCA Release '$Name: $'... Author: Till Straumann <[email protected]> Ctrl-C handling is disabled (compile-time option) ==> Initializing max. timeout to 5. seconds multi_ezca_get_nelem - ezcaGetNelem(): could not find process variable : garbageError: Errors encountered... ??? (see above error messages)
Stephanie Allison
RE: labCA crashes with bad PV Allison, Stephanie
Prev: Re: labCA crashes with bad PV Kay-Uwe Kasemir
Next: Re: labCA crashes with bad PV Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: labCA crashes with bad PV Eric Norum
Next: ArchiveDataServer is ok Liu Shu
