1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ASYN support for PC parallel port (Linux)
To: "Ralph Lange" <[email protected]>, "EPICS Tech Talk" <[email protected]>
Date: Fri, 17 Feb 2006 09:08:04 -0600
Hi Ralph,
I do have an asyn driver for the XIA Saturn DSP processor that uses the EPP port.  However, it is not a "generic" driver, it is specifc to that device.  You might be able to use the low-level part of it as the basis of a general purpose asyn driver.
You can find it at:
http://cars.uchicago.edu/software/epics/dxp
Sent: Fri 2/17/2006 7:27 AM
To: EPICS Tech Talk
Subject: Req: ASYN support for PC parallel port (Linux)
Does anyone have an ASYN based driver for generic PC parallel ports
(EPP?) as register type IO, under Linux?
Thanks!
Ralph
Prev: Req: ASYN support for PC parallel port (Linux) Ralph Lange
Next: segmentation fault in ca_task_initialize running in Linux Margaret Votava
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
