1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Port numbers now official
To: tech talk <[email protected]>
Date: Fri, 17 Feb 2006 14:45:39 -0500
Hi:
I was just using netstat to check if a CA server is running,
couldn't find anything on ports 5064, 5065,
and got confused.
Then I looked again: It said "ca-1", "ca-2".
This is on Mac OS X,
and its /etc/services per default contains:
ca-1            5064/udp    # Channel Access 1
ca-1            5064/tcp    # Channel Access 1
ca-2            5065/udp    # Channel Access 2
ca-2            5065/tcp    # Channel Access 2
#                          Jeffrey Hill <[email protected]> August 2002
I remember that Jeff mentioned registering those port numbers,
so now it's taking effect ;-)
-Kay
Prev: MVME3100 and EPICS (The successor to the MVME2100) a first look Ernest L. Williams Jr.
Next: RE: segmentation fault in ca_task_initialize running in Linux Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: genSub tutorial needed Dennis Nicklaus
