1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: GPIB swap 1014D with 1014
To: "Waggoner, Bill" <[email protected]>
Cc: APS tech-talk <[email protected]>
Date: Wed, 22 Feb 2006 18:26:43 -0600
Hi Bill,
We also use both the 1014D and 1014. Although I have not tried it for several years, I think your evaluation is pretty accurate ... but one can easily replace a 1014D with two 1014s.
By default:
A16 address for the #L0 card is 0x5000
A16 address for the #L1 card is 0x5200
The 1014D covers both address spaces if the base address is set to 0x5000, thereby servicing #L0 and #L1.
So, if you replace the 101D with two 1014s, you don't even have to change your databases.
Ned
Waggoner, Bill wrote:
Greetings from STAR on LI,
We have three subsystems using NI 1014 type GPIB interfaces. All of these have been running for many years, and all are using 3.12 EPICS.
One subsystems uses a 1014D, dual port interface. It was brought to my attention that we have no spare for this system. I was looking into the problems that would arise should we have to swap this with a 1014 mono port interface. We have several spare 1014, and our other option would be to buy another 1014D
From the code, and the device support, the startup scripts, and the state programs we use for the two types of interfaces I see no real differences. The only difference is in the record fields where the dual port has two lines #L0 and #L1 in its database.
Would a swap only involve a database change? What hardware considerations are involved? I have had no previous experience (up to 24 hours ago) with GPIB, and have been perusing the manuals, and tech talk. Normally I would just play, but we are now buttoned up with beam for this system, and wont have access for weeks.
Any answers, and suggestions are greatly appreciated.
Thanks in Advance,
Bill Waggoner
STAR
BNL
PS Eventually.. next year? we might upgrade this to EPICS 3.13 or 3.14.. but time constraints aren’t going to allow that for this run.
-- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.375 / Virus Database: 267.15.11/264 - Release Date: 2/17/2006
GPIB swap 1014D with 1014 Waggoner, Bill
Prev: GPIB swap 1014D with 1014 Waggoner, Bill
Next: It's ok now liushu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: GPIB swap 1014D with 1014 Waggoner, Bill
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
