That at least explains where the line endings got changed. I don't think I like your proposed solution for the following reasons: If you try to build a tree that has DOS line endings using the SUNWspro compiler on Solaris, it does fail. Consider this C construct, which is used in various places in base: #define macro \ multi-line \ macro being \ defined here The Solaris C preprocessor takes the first back-slash to be escaping the following <cr>, and the <lf> immediately following it to be the end of the macro definition. It also reports the following warning on every single #include line it sees: warning: invalid white space character in directive Thus it is not reasonable to expect *all* architectures to build from the exact same source tree. - Even if I untar the source file with Cygwin tar, if I then use a Windows text editor, such as Wordpad, to edit any .l file (in base or in any application), e_flex fails. Unless you configure Cygwin to use DOS line endings, which should fix the problem for *every* C program automatically since it modifies the behaviour of the C runtime library. Do you have some particular objection to doing that? I'm not a Cygwin/Windows user, so I don't know if there's a downside to it. - Most, if not all, other EPICS code that reads ASCII files (.adl files, .db files, .dbd files, etc.) are now tolerant of either type of line terminator. e_flex seems to be the exception. GCC also seems to have bowed under pressure so it also accepts the above macro without complaint, even on Unix systems. I guess this is one of those "be liberal in what you accept" situations, so I'll commit the changes. Flex is third party software and is pretty complex, written using itself. I believe that my changes are correct, but they will need to be tested. - Andrew -- There is no S in exprexxo.
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
