OK, so if I understand this, you're saying the bootROM client
downloads the boot image and disconnects before the data connection
is closed, before the server is listening for the command, and the
server sits there waiting until it times out. But, if the bootROM
client has successfully downloaded the file, shouldn't I see it boot,
and then hang when it tries to download the script file because the
server is still waiting on the original connection? What I see is
basically nothing happening for a long time, then after the seven
minutes are up, I see the vxWorks logo and such, then the script file
is downloaded very quickly. Also, I've noticed a problem w/ WS_FTP
trying to download the same vxWorks.st from the same server - in that
case I get a graphical indicator and it looks like the file transfer
itself is very abnormally slow. In any case, your suggestion seems
worth a shot, even if it's so I can upgrade to solaris 9.
dale
At 02:33 PM 3/1/2006, Andrew Johnson wrote:
Hi Dale,
Dale L. Brewe wrote:
I'm having a bit of an issue trying to get tornado 2.02 to boot
from a RAID network storage appliance (ReadyNAS from Infrant)
running ProFTPD v.1.2.9 under a version of Linux. The problem is
that downloading the boot image takes around 6-7 minutes.
Downloading the script file happens normally, in a couple of seconds.
This sounds like a known issue with the vxWorks bootrom code, which
closes its sockets in the wrong order. We came across this first
with the Solaris 9 FTP server, which derives from a different
codebase than the previous Solaris FTP servers and is less liberal
in what it will accept.
There are two TCP sockets involved with an FTP file transfer, the
command socket and the data socket. The vxWorks FTP library allows
application code rather a lot of control over the data transfer
process since it wants to allow the data socket to be connected
directly to some code (such as the ld command) that can perform I/O
directly on the socket without having to buffer all the data coming
through it. This means that the library isn't able to completely
enforce the protocol by itself, and an application can cause problems.
An FTP client is supposed to close the data socket when it's
finished reading the data, and then close the command
socket. Unfortunately the vxWorks bootrom code does that in the
wrong order, and thus doesn't correctly follow the FTP protocol
defined in RFC959. Older FTP servers don't seem to mind this, but
some newer servers will not look for a new command on the command
socket until the data socket has been closed (this may be for
security reasons).
The fix involves applying this patch (which applies to all BSPs) to
your target/config/all/bootConfig.c file, then rebuilding and
flashing the bootrom.
- Andrew
Index: bootConfig.c
RCS file: /home/phoebus/TORNADO5/cvsroot/config/all/bootConfig.c,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -r1.2 -r1.3
--- bootConfig.c 12 Mar 2003 22:53:28 -0000 1.2
+++ bootConfig.c 22 Jan 2004 21:18:42 -0000 1.3
@@ -2492,11 +2492,11 @@
while ((read (fd, command, sizeof (command))) > 0);
+ close (fd);
if (bootFtp)
(void) ftpCommand (errFd, "QUIT",0,0,0,0,0,0);
- close (fd);
close (errFd);
return (OK);
@@ -2510,5 +2510,6 @@
+ close (fd);
if (bootFtp)
@@ -2520,6 +2521,7 @@
char buf [100];
int errBytesRecv = fioRead (errFd, buf, sizeof (buf));
+ close (fd);
if (errBytesRecv > 0)
@@ -2530,7 +2532,6 @@
- close (fd);
close (errFd);
return (ERROR);
Dale L. Brewe
PNC-CAT/Argonne National Laboratory
ph: 630 252 0582 fax: 630 252 0580
Mail:
Bldg 435E sector 20
9700 S. Cass Ave.
Argonne, IL 60439
- Re: vxWorks and ProFTPD Andrew Johnson
- vxWorks and ProFTPD Dale L. Brewe
RE: vxWorks and ProFTPD Paul Sichta
<2006>
2025
<2006>
2025
