1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Gateway error
To: "'Leicester, PJ \(Pete\)'" <[email protected]>, <[email protected]>
Cc: "Ken Evans" <[email protected]>
Date: Fri, 3 Mar 2006 11:36:45 -0700
Title: Message
Thanks for your bug report. I created an entry in the bug tracking system.
Jeff
-----Original Message-----
From: Leicester, PJ (Pete) [mailto:[email protected]]
Sent: Friday, March 03, 2006 4:03 AM
To: [email protected]
Subject: Gateway error
We have been running the new gateway 2.0 on epics 3.14.8.2 for a month or more with good results. It has been stable even with large transfers.
However last evening a problem occurred with the gateway and it had to be restarted. Unfortunately the only information I have is the following gateway log.
Can anyone hazard a guess as to what was going on ?
We are running the gateway on Redhat Enterprise Linux 4.
Also we are running the alarm handler through the gateway too which I understand from previous Techtalk emails is a bad thing (DBE_VALUE v DBE_ALARM events subscription conflict) and something we have to address. Could this have caused the problem?
Pete Leicester
Diamond Light Source
Feb 27 09:01:02 PV Gateway Version 2.0.0.0 [Jan  9 2006 11:30:43]
EPICS 3.14.8.2 PID=2598 ServerPID=2597
EPICS_CA_ADDR_LIST=172.23.255.255
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=5064
EPICS_CA_MAX_ARRAY_BYTES=3000000
EPICS_CAS_INTF_ADDR_LIST=172.23.194.129
EPICS_CAS_SERVER_PORT=5064
EPICS_CAS_IGNORE_ADDR_LIST=172.23.194.129
Running as user gate on host serv0013.cs.diamond.ac.uk
Statistics PV prefix is CtoP:serv0013
Feb 28 14:42:43 Warning: Virtual circuit unresponsive 172.23.248.87:5064
Unexpected problem with CA circuit to server "172.23.248.87:5064" was "No route to host" - disconnecting
Feb 28 14:58:03 !!! Errlog message received (message is above)
Feb 28 14:58:03 Warning: Virtual circuit disconnect 172.23.248.87:5064
Feb 28 15:36:41 Warning: Virtual circuit unresponsive 172.23.248.60:5064
CAS: TCP socket send to "172.23.198.8:32805" failed because "No route to host"
Feb 28 15:50:15 !!! Errlog message received (message is above)
Unexpected problem with CA circuit to server "172.23.248.60:5064" was "No route to host" - disconnecting
Feb 28 15:52:01 !!! Errlog message received (message is above)
Feb 28 15:52:01 Warning: Virtual circuit disconnect 172.23.248.60:5064
Feb 28 16:15:46 Warning: Virtual circuit unresponsive 172.23.248.109:5064
CAS: TCP socket send to "172.23.198.8:32813" failed because "No route to host"
Feb 28 16:16:40 !!! Errlog message received (message is above)
Unexpected problem with CA circuit to server "172.23.248.109:5064" was "No route to host" - disconnecting
Feb 28 16:31:07 !!! Errlog message received (message is above)
Feb 28 16:31:07 Warning: Virtual circuit disconnect 172.23.248.109:5064
Mar 01 10:41:06 Warning: Virtual circuit unresponsive 172.23.248.25:5064
Mar 01 10:41:07 Warning: Virtual circuit unresponsive 172.23.248.27:5064
Mar 01 10:41:09 Warning: Virtual circuit unresponsive 172.23.248.83:5064
Mar 01 10:41:11 Warning: Virtual circuit unresponsive 172.23.248.195:5064
Mar 01 10:41:15 Warning: Virtual circuit unresponsive 172.23.248.164:5064
Mar 01 10:41:15 Warning: Virtual circuit unresponsive 172.23.248.24:5064
Mar 01 10:41:16 Warning: Virtual circuit unresponsive 172.23.248.144:5064
Unexpected problem with CA circuit to server "172.23.248.25:5064" was "No route to host" - disconnecting
Mar 01 10:56:27 !!! Errlog message received (message is above)
Mar 01 10:56:27 Warning: Virtual circuit disconnect 172.23.248.25:5064
Unexpected problem with CA circuit to server "172.23.248.83:5064" was "No route to host" - disconnecting
Mar 01 10:56:29 !!! Errlog message received (message is above)
Mar 01 10:56:29 Warning: Virtual circuit disconnect 172.23.248.83:5064
CAS: client 172.23.198.11:32812 disconnected because "No route to host"
Mar 01 10:56:32 !!! Errlog message received (message is above)
Unexpected problem with CA circuit to server "172.23.248.195:5064" was "No route to host" - disconnecting
Mar 01 10:56:32 Warning: Virtual circuit disconnect 172.23.248.195:5064
Unexpected problem with CA circuit to server "172.23.248.164:5064" was "No route to host" - disconnecting
Mar 01 10:56:36 !!! Errlog message received (message is above)
Mar 01 10:56:36 Warning: Virtual circuit disconnect 172.23.248.164:5064
Unexpected problem with CA circuit to server "172.23.248.24:5064" was "No route to host" - disconnecting
Mar 01 10:56:36 Warning: Virtual circuit disconnect 172.23.248.24:5064
Unexpected problem with CA circuit to server "172.23.248.144:5064" was "No route to host" - disconnecting
Mar 01 10:56:37 !!! Errlog message received (message is above)
Mar 01 10:56:37 Warning: Virtual circuit disconnect 172.23.248.144:5064
Unexpected problem with CA circuit to server "172.23.248.27:5064" was "No route to host" - disconnecting
Mar 01 10:56:44 !!! Errlog message received (message is above)
Mar 01 10:56:44 Warning: Virtual circuit disconnect 172.23.248.27:5064
CAS: client 172.23.200.84:1090 disconnected because "No route to host"
Mar 01 10:57:00 !!! Errlog message received (message is above)
Mar 01 16:54:11 Warning: Virtual circuit unresponsive 172.23.248.24:5064
Mar 01 16:54:32 Warning: Virtual circuit unresponsive 172.23.248.27:5064
Mar 01 16:54:40 Warning: Virtual circuit unresponsive 172.23.248.83:5064
Unexpected problem with CA circuit to server "172.23.248.27:5064" was "Connection reset by peer" - disconnecting
Mar 01 16:54:54 !!! Errlog message received (message is above)
Mar 01 16:54:54 Warning: Virtual circuit disconnect 172.23.248.27:5064
Mar 01 16:54:57 Warning: Virtual circuit unresponsive 172.23.248.195:5064
Unexpected problem with CA circuit to server "172.23.248.24:5064" was "Connection reset by peer" - disconnecting
Mar 01 16:54:58 !!! Errlog message received (message is above)
Mar 01 16:54:58 Warning: Virtual circuit disconnect 172.23.248.24:5064
Unexpected problem with CA circuit to server "172.23.248.195:5064" was "Connection reset by peer" - disconnecting
Mar 01 16:55:18 !!! Errlog message received (message is above)
Mar 01 16:55:18 Warning: Virtual circuit disconnect 172.23.248.195:5064
Unexpected problem with CA circuit to server "172.23.248.83:5064" was "Connection reset by peer" - disconnecting
Mar 01 16:55:26 !!! Errlog message received (message is above)
Mar 01 16:55:26 Warning: Virtual circuit disconnect 172.23.248.83:5064
Unexpected problem with CA circuit to server "172.23.252.107:5064" was "Connection reset by peer" - disconnecting
Mar 01 17:06:40 !!! Errlog message received (message is above)
Mar 01 17:06:40 Warning: Virtual circuit disconnect 172.23.252.107:5064
Mar 01 17:18:05 !!! Errlog message received (message is above)
Mar 01 17:18:05 Warning: Virtual circuit disconnect 172.23.248.195:5064
Mar 01 17:20:37 !!! Errlog message received (message is above)
Mar 01 17:20:37 Warning: Virtual circuit disconnect 172.23.248.195:5064
A call to "assert (item.pList == this)" failed in ../../../../src/cas/generic/st/ioBlocked.cc line 112.
Mar 01 18:30:04 !!! Errlog message received (message is above)
EPICS Release EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$.
Current time Wed Mar 01 2006 18:30:04.20652000.
Please E-mail this message to Jeff Hill [email protected] or to [email protected]
Calling epicsThreadSuspendSelf()
Mar 01 19:28:11 PV Gateway Ending (SIGTERM)
Mr P J Leicester
Senior Software Engineer
Diamond Light Source Ltd.
Rutherford Appleton Laboratory
Chilton
Didcot
OX11 0QX
Tel: 01235 778478
Gateway error Leicester, PJ (Pete)
Prev: RE: drvAscii codes Al Honey
Next: calcPerform expressions: 'NOT' operator Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Gateway error Leicester, PJ (Pete)
Next: RE: drvAscii codes Porter, Rodney R.
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
