1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: drvAscii codes
To: "Porter, Rodney R." <[email protected]>, [email protected]
Cc: [email protected], [email protected]
Date: Wed, 08 Mar 2006 09:30:08 +0000
thanks for the replies. I changed to \x02 but I still get "\x02" coming out.
I'm using version 1.4 of drvAscii which is what was in my (jac) release of R3.13.8. Sounds like I need to move to v2 to cure the problem(?).
Thanks
Ian
Porter, Rodney R. wrote:
Ian, The documentation says that what you have should work. I practice, I
have used \x03 and \x02 instead of \003 and \002 for a similar device
and it has worked. Let me know if this fixes your problem.
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
Argonne National Laboratory 9700 So. Cass Ave Argonne, IL 60439 USA Ph. (630) 252-7151
E-mail: [email protected] IPNS website: www.pns.anl.gov
-----Original Message-----
From: Ian A Smith [mailto:[email protected]] Sent: Friday, March 03, 2006 4:10 AM
To: [email protected]
Subject: drvAscii codes
I'm trying to get epics to talk to an (awkward) piece of equipment.  It
requires: "[stx]command[etx][cr][lf]", where of course, [stx] and [etx]
are ascii 2 and 3.
I've succeeded in puting the [etx] on the end of lines but I get the
literal string "\002" instead of [stx] at the start, so I'm looking for
help!
The record which successfully puts [etx] in line termination is:
record(stringout,"scu2CCS:shutter:coms:txCmd") {
     field(DESC,"string output record")
     field(SCAN,"Passive")
     field(PINI,"YES")
     field(PHAS,"0")
     field(EVNT,"0")
     field(DTYP,"Ascii SIO")
     field(DISV,"1")
     field(SDIS,"0.000000000000000e+00")
     field(DISS,"NO_ALARM")
     field(PRIO,"LOW")
     field(FLNK,"0.000000000000000e+00")
     field(VAL,"\003\r\n")
     field(DOL,"\003\r\n")
     field(OMSL,"closed_loop")
     field(OUT,"@/pty/shutterM <writeCmt %s>")
     field(SIOL,"0.000000000000000e+00")
     field(SIML,"0.000000000000000e+00")
     field(SIMS,"NO_ALARM")
     field(IVOA,"Continue normally")
     field(IVOV,"")
and the record which fails to put [stx] in the command line is:
record(stringin,"scu2CCS:shutter:test") {
     field(DESC,"string input record")
     field(SCAN,"10 second")
     field(PINI,"NO")
     field(PHAS,"0")
     field(EVNT,"0")
     field(DISV,"1")
     field(PRIO,"LOW")
     field(VAL,"string")
     field(INP,"@/pty/shutterM <\002SUI><%s>")
TIA
Ian A Smith               Telephone: +44 (0) 131 668 8255
Royal Observatory         Fax:       +44 (0) 131 668 8314
Blackford Hill            Web:       http://www.roe.ac.uk/
Edinburgh
EH9 3HJ
UK
RE: drvAscii codes Porter, Rodney R.
Prev: Re: cross compiling EPICS for etrax Andrew Johnson
Next: compatibility between 3.13.10 and 3.14.8 Jane Richards
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: drvAscii codes Porter, Rodney R.
Next: RE: drvAscii codes Al Honey
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
