I am building archiveViewer JSP on Scientific Linux Fermi LTS 3.0
and it failed with the following errors:
d0olk->ant configure_jsp
Buildfile: build.xml
-create_build_dir:
build_all:
[javac] Compiling 842 source files to
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/build
[javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunPNGEncoderAdapter.java:41: error: Class or interface `javax.imageio.ImageIO' not found in import.
[javac] import javax.imageio.ImageIO;
[javac] ^
[javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:44: error: Class or interface `com.sun.image.codec.jpeg.JPEGEncodeParam' not found in import.
[javac] import com.sun.image.codec.jpeg.JPEGEncodeParam;
[javac] ^
[javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:124: error: Type `JPEGImageEncoder' not found in the declaration of the local variable `encoder'.
[javac] JPEGImageEncoder encoder =
JPEGCodec.createJPEGEncoder(outputStream);
[javac] ^
[javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/org/jfree/chart/encoders/SunJPEGEncoderAdapter.java:125: error: Type `JPEGEncodeParam' not found in the declaration of the local variable `param'.
[javac] JPEGEncodeParam param =
encoder.getDefaultJPEGEncodeParam(bufferedImage);
[javac] ^
[javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:17: error: Class or interface `javax.swing.plaf.basic.BasicToolTipUI' not found in import.
[javac] import javax.swing.plaf.basic.BasicToolTipUI;
[javac] ^
[javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:25: error: Superclass `BasicToolTipUI' of class `epics.archiveviewer.xal.view.tooltip.MultiLineToolTipUI' not found.
[javac] public class MultiLineToolTipUI extends BasicToolTipUI
[javac] ^
[javac]
/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/src/epics/archiveviewer/xal/view/tooltip/MultiLineToolTipUI.java:0: internal compiler error: Segmentation fault
[javac] Please submit a full bug report,
[javac] with preprocessed source if appropriate.
[javac] See <URL:http://bugzilla.redhat.com/bugzilla/> for
instructions.
BUILD FAILED
file:/online/products/epics/v3_14_8_2/extensions/src/archive_viewer-1-0-4/build.xml:21: Compile failed; see the compiler error output for details.
My settings are:
d0olk->echo $JAVA_HOME
/usr/java/j2sdk1.4.2_08
d0olk->echo $CATALINA_HOME/
/mnt/tomcat/jakarta-tomcat-3.2.4/
Can someone give any suggestions?
Vladimir
- Re: archiveViewer JSP build Jiro Fujita
FW: Eclipse workshop, March 24th Chestnut, Ronald P.
<2006>
2025
<2006>
2025
