1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: JAC and GEMINI!
To: "tech_talk" <[email protected]>
Date: Wed, 15 Mar 2006 12:32:57 -1000
This is intended to grab the attention of software folk at the JAC and
Gemini as I am fairly certain that they are living with the bc635 driver
(Bancomm) bug and perhaps unaware of that fact!
Sorry for the inconvenience to others but I no longer know who the
primaries are at those two observatories.
AH
-----Original Message-----
Sent: Wednesday, March 15, 2006 9:00 AM
To: tech_talk
Subject: bc635 driver bug (Bancomm)
Aloha
A bug has been found in the bc635 driver (Bancomm). The bug is probably
not affecting all users.
If you have a task named 'tSyncANSIClk' on your IOC then you should be
concerned. If you do 'ti "tSyncANSIClk"' and you do not see the
VX_FP_TASK status in the display then you should be worried.
Said task performs floating-point calculations but does not save and
restore the floating-point registers on task switch. Said task runs at a
very high priority but only once every 10 seconds. The consequence is
that any task performing floating-point calculations could be seriously
affected (in experiments I have seen a system run safely for 800,000,000
iterations before the problem occurs).
At the Keck observatory we have experienced various unexplained
behaviors for a decade (including NaN values appearing seemingly 'out of
the blue') and I contend that most, if not all, of those problems can be
explained by this bug.
The problem and solution follow.
In ErDriverInit() within the file bc635TS.c there is the following code:
      /* if the real time clock is periodically to be synched, spawn a
         task to do so every 10 seconds (TBD: check parameters) */
      if ( syncRTC ) {
          ( void ) taskSpawn( "tSyncRTCClk", 10, 0, 5000, periodRun, 10,
                              bc635SyncRTC, drv );
      /* if the VxWorks ANSI clock is periodically to be synched, spawn
a
      if ( syncSys ) {
          ( void ) taskSpawn( "tSyncANSIClk", 10, 0, 5000, periodRun,
10,
                              bc635SyncSys, drv );
The second task bc635SyncSys() calls bc635GetTimespec() and that
function performs several floating point operations.
The solution is to change the '0' options parameter, in the taskSpawn,
to
VX_FP_TASK as follows:
      if ( syncRTC ) {
          ( void ) taskSpawn( "tSyncRTCClk", 10, VX_FP_TASK, 5000,
                              periodRun, 10, bc635SyncRTC, drv );
a
      if ( syncSys ) {
          ( void ) taskSpawn( "tSyncANSIClk", 10, VX_FP_TASK, 5000,
                              periodRun, 10, bc635SyncSys, drv );
I suspect it is possible to set the appropriate status in the task
control block (TCB) from the vxworks shell or at least with a tiny piece
of C code. I am playing with that now.
Hope this helps some of you!
Allan Honey
Re: JAC and GEMINI! Matthieu Bec
Prev: Re: archiveViewer JSP build, archiver under R3.14.8 Kay-Uwe Kasemir
Next: Re: JAC and GEMINI! Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: bc635 driver bug (Bancomm) Al Honey
