On March 9th I committed base/configure file changes to embed the new
Visual c++ 2005 *.manifest files into a library or executable. The binary
install rule in RULES_BUILD will no longer have the problem causing "$<*"
for installation of the *.manifest files. These changes will appear in the
next R3.14 base release.
Janet
Ralph Lange wrote:
Hi Dale,
this is an error I found and reported two months ago (see attached mails
for analysis, workaround and Janet's reply).
I don't know the current status, but I created Mantis Bug Report 244 now
to make sure the bug is visible and searchable. (I really should have
created the Mantis entry back then.)
Sorry for the inconveniences,
Ralph
Dale L. Brewe wrote:
I'm having a bit of a problem building epics base 3.14.8.2 w/ the
win32-x86 platform. The build progresses ok for awhile til I get
output from gnumake (3.78.1 or 3.80) that ends w/
Subject:
Re: 3.14.8 / cygwin dependency
Ralph Lange <[email protected]>
Date:
Mon, 23 Jan 2006 15:47:19 +0100
To:
Janet Anderson <[email protected]>
To:
CC:
EPICS Core Talk <[email protected]>
Hi Janet,
I found the change that broke the non-cygwin build:
In RULES_BUILD 1.88.2.14 the line to install binaries was changed from
@$(INSTALL_PRODUCT) -d -m 555 $< $(INSTALL_BIN)
to
ifdef WIN32
@$(INSTALL_PRODUCT) -d -m 555 $<* $(INSTALL_BIN)
else
endif
Immediately afterwards the wildcard was taken back for BORLAND
compilations.
The problem is that the standard Windows shell - or whatever make uses
to call programs on non-cygnus systems - does not allow wildcards in
this place. Changing the "$<*" to "$(wildcard $<*)" lets make do the
wildcard job, which should be the better option, anyway.
What exactly were you trying to "catch" with that wildcard? For my
Microsoft non-cygnus system I actually can't think of any other files
that would be matched by it.
I didn't commit any changes to CVS as I wasn't sure about the usefulness
of that wildcard.
So - if we need the wildcard, please change it as shown above, which
will work everywhere. If we don't need the wildcard, going back to the
traditional line is fine with me.
Cheers,
Ralph
Subject:
Date:
Wed, 25 Jan 2006 13:21:45 -0600
To:
Ralph Lange <[email protected]>, Hill Jeff <[email protected]>
To:
The command line wildcard was introduced 2 days before R3.14.8 was released
as a quick fix for EPICS base bug # 231. See the bug notes for details.
The new Microsoft Visual c++ 2005 linker creates a .manifest file with each
executable and library (e.g. ca.dll ca.dll.manifest). It seems that this
file
needs to be installed in the same directory as the executable/dll. This
was a
temporary change I committed until we better understand how manifest
files are
used and whether or not we need new CONFIG files for the new compiler.
Ken Evans
is now looking into manifests to better understand them and to solve
problems
we have with manifests for java jni libraries. Using a wildcard function
seems
like a better way to implement the quick fix.
Janet
Ralph Lange wrote:
Hi -
I was thinking and talking about this issue a bit more:
Now I would say it's generally bad to use wildcards for what is done
within make target chains, as this introduces hidden dependencies that
make never has a chance to know about and resolve correctly.
Janet (or Jeff): What was this wildcard introduced for? As it's not
for the Borland (by ifdef) and not for the Microsoft (by my
experience), it can only affect the MinGW or Cygnus compilers. Are
there other files generated apart from the target dll or exe? Or does
the compiler name the target dll or exe different from the usual make
target name? Wouldn't it be possible and more appropriate to add
targets or change the target name in that case?
Cheers,
Ralph
Jeff Hill wrote:
Thanks Rlaph.
Actually surprised that I havent seen this here.
Jeff
-----Original Message-----
From: Ralph Lange [mailto:[email protected]] Sent: Monday,
January 23, 2006 7:47 AM
To: Janet Anderson
Cc: EPICS Core Talk
Subject: Re: 3.14.8 / cygwin dependency
Hi Janet,
to
ifdef WIN32
else
endif
compilations. The problem is that the standard Windows shell - or
whatever make uses to call programs on non-cygnus systems - does not
allow wildcards in this place. Changing the "$<*" to "$(wildcard
$<*)" lets make do the wildcard job, which should be the better
option, anyway.
files that would be matched by it.
usefulness of that wildcard.
the traditional line is fine with me.
Cheers,
Ralph
- problem building 3.14.8.2 with win32-x86 Dale L. Brewe
- Re: problem building 3.14.8.2 with win32-x86 Ralph Lange
RE: building 3.14.8.2 on win32-x86 Jeff Hill
Was this EPICS? Lawrence T. Hoff
<2006>
2025
Fwd: problem building 3.14.8.2 with win32-x86 Dale L. Brewe
<2006>
2025
