On Fri, 2006-03-24 at 16:35 -0800, Zhou, Jingchen wrote:
> Hi Ernest,
> Xvfb (Virtual Framebuffer X server) provides a X server that can run on machines with no display hardware and no physical input devices. It emulates a dumb framebuffer using virtual memory. The primary usage of this server was intended to be server testing; other usages include testing clients, doing batch processing with Xvfb as a background rendering engine. We have found that Xvfb provides an excellent solution for us to run a X based application on production server machines that don't have X server on them. The application can be started at booting time as a background process and without a visible display either locally or remotely. The EPICS Alarm handle (a standalone program) used here in SLAC as Steph pointed out is a good example for such usage.
> Xvfb should be a part of X11R6. If you don't have one, you can get it via
> ftp ferret.wrc.noaa.gov:
> Name (ferret.wrc.noaa.gov:kobrien): anonymous
> 331 Guest login ok, send ident as password.
> Password: your_email_address
> 230 Guest login ok, access restrictions apply.
> ftp> cd special_request/xvfb/solaris
> ftp> get X11R6.1_bin.tar.Z
> To start up the virtual frame buffer, type:
> % /usr/X11R6/bin/Xvfb :1 -screen 0 1152x900x8 &
> Any graphics output going to display 1 will be sent to the virtual memory.
> You should add this line into a startup script in boot sequence.
> To set the current display to use the virtual framebuffer for graphics display, type:
> $ setenv DISPLAY :1.0
Thank You. That works perfectly. :)
Ernest
> Jingchen
> -----Original Message-----
> From: Allison, Stephanie [mailto:[email protected]]
> Sent: Friday, March 24, 2006 8:42 AM
> To: Ernest L. Williams Jr.; EPICS tech-talk
> Cc: [email protected]
> Subject: RE: AlarmHandler as a daemon or service
> Hi Ernest,
> At SPEAR, we run one "standalone" ALH which is started at system reboot. In order to get around the need for an X terminal, it uses Xfvb (Virtual Framebuffer X Server) which is started before the standalone ALH. The purpose of this ALH is simply to send alarms to cmlog. It's started with these options:
> To use Xfvb:
> setenv DISPLAY :1.0
> # -oCM = log operator mods to CMLOG
> # -wCM = wordy CMLOG messages
> # -aCM = log alarms to CMLOG
> # -m 2000 = max number of alarms in the alarm file
> # -s = silent
> # -S = passive
> # -noerrorpopup
> # -l $ALHLOGFILES = where log files are
> # -f $ALHCONFIGFILES = where config files are
> # -a Alarms.log = name of alarm log files
> # -o OpMods.log = name of op mod log files
> I left the Alarms.log and OpMods.log for my own use.
> (BTW - the "wordy" option was added since we wanted more information in the text).
> I added a special cmlog browser to take messages from the cmlogServer as they come and send them to a server on our RDB machine that sticks them into RDB so we can see alarm events (along with events from our other clients like channelWatcher and other monitoring programs) from the web. Maybe someday we get rid of cmlogServer and have ALH and channelWatcher log directly to the RDB server.
> Works OK for us except our version of ALH is very old and has bugs which are most probably fixed in the newer version. When I get some time, I'll upgrade.
> Stephanie Allison
> SPEAR/SSRL and LCLS/SLAC
- RE: AlarmHandler as a daemon or service Zhou, Jingchen
ChannelArchiver update Kay-Uwe Kasemir
<2006>
2025
RE: AlarmHandler as a daemon or service Liyu, Andrei
<2006>
2025
