1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: gateway enum writes
To: <[email protected]>
Date: Tue, 28 Mar 2006 17:53:20 +0100
Title: Message
I am getting some strange behaviour when writing enumerations through the Gateway (version 2.0.0.0 on 3.14.8.2 and RedHat Enterprise 4).
The problem first showed itself in edm when pressing a button on a edm screen to send the value resulted in the following error:
    CA.Client.Exception...............................................
        Warning: "Virtual circuit unresponsive"
        Context: "diamrs0005l.diamond.ac.uk:6064"
        Source File: ../tcpiiu.cpp line 896
        Current Time: Tue Mar 28 2006 16:19:01.334736000
I did some further tests using caput with similar results:
    [pjl45@pc0005 pjl45]$ caput  -w15 GDA:scaler2.CNT Count
    Old : GDA:scaler2.CNT                Done
    Read operation timed out: PV data was not read.
    New : GDA:scaler2.CNT
        Warning: "Virtual circuit disconnect"
        Context: "op=0, channel=GDA:scaler2.CNT, type=DBR_TIME_STRING, count=1, ctx="diamrs0005l.diamond.ac.uk:6064""
        Source File: ../getCopy.cpp line 82
        Current Time: Tue Mar 28 2006 17:04:24.488496000
Despite the above error message the write does actually reach the IOC.
However if I now try the change the value back as follows:
    [pjl45@pc0005 pjl45]$ caput  -w15 GDA:scaler2.CNT Done
    Old : GDA:scaler2.CNT                Count
        Current Time: Tue Mar 28 2006 17:22:36.167980000
I get an error again however this time the 'Done' value gets written to the IOC exactly ONE MINUTE after I entered the caput command. This is long after the caput command has timed out so it appears the gateway is responsible for the delay?
Has anyone any idea what may be happening? Is there a 60 second timeout in CA or the gateway which may give a clue as to what I am seeing?
(For the record this test was done with a very lightly loaded test gateway serving only 20 or so PV's. Also using caput -w70 results in the same timeouts)
Pete  Leicester
Senior Software Engineer
Diamond Light Source Ltd.
Rutherford Appleton Laboratory
Chilton
Didcot
OX11 0QX
Tel: 01235 778478
Re: gateway enum writes Martin L. Smith
Re: gateway enum writes Tim Mooney
Prev: ChannelArchiver update Kay-Uwe Kasemir
Next: Re: gateway enum writes Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
