1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stringin/out <-> sub record ?
To: "Laznovsky, Michael" <[email protected]>
Cc: [email protected]
Date: Thu, 30 Mar 2006 09:37:30 -0600
Laznovsky, Michael wrote:
Hi- how can I get strings in & out of subroutine records?
It appears that the sub record tries to convert all its inputs to "double" before calling the user function, and complains if it fails. All I want is to read/write actual strings from inside the function.
Right, you can't use the INP/OUT fields of a sub record for anything other than doubles. As Andy Foster has said you could use a genSub record, or if you only need one string you could use the psub->desc field of the regular subroutine record (although it's only 28 characters long). You could also consider writing your code as device support for the stringin and/or stringout records.
- Andrew
There is no S in exprexxo.
stringin/out <-> sub record ? Laznovsky, Michael
Prev: RE: gateway enum writes Mark Rivers
Next: Re: gateway enum writes Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stringin/out <-> sub record ? Martin L. Smith
Next: SIGs Dalesio, Leo `Bob`
