1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: AlarmHandler as a daemon or service
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 30 Mar 2006 12:58:03 -0500
Ernest L. Williams Jr. wrote:
Two questions:
(1) How many sites used the EPICS AlarmHandler.
(2) Has anyone changed the EPICS AlarmHandler to run in daemon mode or
as a service?
This would be a useful mode when the logging option is used.
So, basically we would need a commandline option to enable this and give
us an alhLogger, ah?
Ernest,
I gave a talk at the collaboration meeting last spring about our use of the alarm handler at Jefferson Lab. You can read the slides here:
http://www-ssrl.slac.stanford.edu/lcls/epics/Talks/ThurAM/Bevins_Epics2005April_Alarms.ppt
Basically, we run an instance of alh on a dedicated machine which makes the audible alarms in the control room and logs to CMLOG. Operators run local instances of alh to acknowledge alarms, get guidance for alarms, etc. We generate our config files automatically in perl and we have a Tcl/Tk based tool that allows for masking off alarms from portions of the machine that are not active using PV's hosted in a Proxy IOC. (The PIOC is a local development that uses the pcas to serve PVs that are created/deleted on demand for "sponsoring" clients.)
There are various enhancements to Cdev and alh that we made to support this configuration, which I promised to release. That should happen Real Soon Now....
--Brian
Brian S. Bevins, PE
Computer Scientist / Mechanical Engineer
Thomas Jefferson National Accelerator Facility
     "Progress, far from consisting in change, depends on retentiveness.
      Those who cannot remember the past are condemned to repeat it."
                                                     -- George Santayana
AlarmHandler as a daemon or service Ernest L. Williams Jr.
Prev: RE: gateway enum writes Mark Rivers
Next: RE: SIGs Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: AlarmHandler as a daemon or service Maren Purves
Next: RE: AlarmHandler as a daemon or service Allison, Stephanie
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
