1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Exiting IOC
To: <[email protected]>, <[email protected]>
Date: Sun, 2 Apr 2006 20:46:42 -0500
One way to do this, but probably not the most elegant, is to call your C cleanup function directly at the end of your main() routine for that IOC.
int main(int argc,char *argv[])
        if(argc>=2) {
        iocsh(argv[1]);
        epicsThreadSleep(.2);
    iocsh(NULL);
    /* Call your cleanup function here */
    return(0);
Sent: Sun 4/2/2006 7:58 PM
To: [email protected]
Subject: Exiting IOC
Dear ALL;
When I type "exit" on IOC shell, I would like to call a particular function to return system resource and then want to terminate the IOC. Is there any mechanism to register the particular function?
Now, I register the particular function as IOC shell command and I call it on the shell before finish IOC. But, I forget it frequently, so, it is inconvenient.
Thank you.
Kukhee Kim
April 1, 2006
Kukhee Kim
National Fusion Research Center
52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
Korea
Email: [email protected]
Tel: +82 42 870 1616     Fax: +82 42 870 1609      Cell: +82 17 513 4849
Prev: Exiting IOC kimkh
Next: LabVIEW and ChannelAccess? Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Exiting IOC Andrew Johnson
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
