1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EpicsHostArch.pl for Intel OS X machines?
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 4 Apr 2006 21:24:59 -0500
On Apr 4, 2006, at 9:15 PM, Ernest L. Williams Jr. wrote:
Don't you want to leave it as "thread-multi-2level"?
Apple uses a new ABI which means the same binary runs on PPC and INTEL,
hmmm?
I would use whatever GCC uses to make the "CROSS".
True, and EPICS already has the configure/os/xxxx files ('EPICS_HOST_ARCH=darwin-fat') for this.  It does double the compile time and object module sizes, though.   I'm not sure that machines are fast enough and disks big enough for this to no longer be a problem.   I guess the easiest approach is to have the EpicsHostArch shell and perl scripts return darwin-fat.  If you want faster builds and smaller files you would manually set EPICS_HOST_ARCH to darwin-ppc or darwin-x86 as appropriate.
Are you OS X users out there okay with this?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: EpicsHostArch.pl for Intel OS X machines? Andrew Johnson
EpicsHostArch.pl for Intel OS X machines? Eric Norum
Re: EpicsHostArch.pl for Intel OS X machines? Ernest L. Williams Jr.
Prev: Re: EpicsHostArch.pl for Intel OS X machines? Ernest L. Williams Jr.
Next: Re: AlarmHandler as a daemon or service Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: EpicsHostArch.pl for Intel OS X machines? Andrew Johnson
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
