1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Ethernet/IP Device Support and CompactLogix
To: Kay-Uwe Kasemir <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 06 Apr 2006 11:20:54 -0400
Kay,
Actually, it looks like there may be another interpretation. The product name is defined as (DeviceNet?) type SHORT_STRING. I don't know where this is defined but it looks like it may be: "a single byte length field and 'n' data bytes".
In which case the Product Name is being returned inside a longer field. The Product Name is less than 32 characters but the data field it is returned in is longer than 32 bytes.
EIP_check_interface() rejects the product name because is finds the length of the data returned >32, even though the string length is less than 32.
John
Kay-Uwe Kasemir wrote:
On Apr 6, 2006, at 10:22 , John Dobbins wrote:
I just found in Volume I : CIP Common Specification, Release 1.0, page 5-10
"Product Name:
This text string should represent a short description of the product/product family represented by the product code in attribute 3. The same product code may have a variety of product name strings. The maximum number of characters in this string is 32."
Excellent, so now you can sue the makers of ControlLogix for violating the spec ;-)
How _did_ you get a copy of the updated specs?
-Kay
Re: Ethernet/IP Device Support and CompactLogix Carl Cork
Ethernet/IP Device Support and CompactLogix John Dobbins
Re: Ethernet/IP Device Support and CompactLogix Kay-Uwe Kasemir
Re: Ethernet/IP Device Support and CompactLogix John Dobbins
Prev: Re: Ethernet/IP Device Support and CompactLogix John Dobbins
Next: Re: Ethernet/IP Device Support and CompactLogix Carl Cork
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
