1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: NewFocus 8752
To: "Maximilien J. Collon" <[email protected]>, <[email protected]>
Date: Wed, 12 Apr 2006 13:15:55 -0500
Hi Max,
There is a pure database solution (no C code) for the 8752 in the
synApps "ip" module, called picoMotor.db  It uses asyn records for the
I/O, so it should work with serial or TCP/IP.  It uses "transform" and
"scalcout" records, which are from the "calc" module in synApps.
> -----Original Message-----
> From: Maximilien J. Collon [mailto:[email protected]]
> Sent: Wednesday, April 12, 2006 6:10 AM
> To: [email protected]
> Subject: NewFocus 8752
> Hi,
> I was wondering if somebody has developed EPICS device support for a
> NewFocus Picomotor Ethernet controller 8752? We would like to talk via
> tcp/ip and this unit to 6 picomotors, which are attached to it. As an
> alternative we could also use RS232 communications with the 8752.
> Any help would be greatly appreciated.
> Thanks and with kind regards,
> Max
> Maximilien J. COLLON
> cosine Research BV :: Tel +31 71 528 49 69
> Niels Bohrweg 11   :: Fax +31 71 528 49 63
> NL-2333 CA Leiden  :: Web http://cosine.nl
Prev: Re: NewFocus 8752 Joe Sullivan
Next: AW: NewFocus 8752 Maximilien J. Collon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: AW: NewFocus 8752 Maximilien J. Collon
Next: Re: AlarmHandler - filtering vs. HYST Brian McAllister
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
