1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: streamDevice/Asyn Error: Businterface not found
To: <[email protected]>, "Dirk Zimoch" <[email protected]>
Date: Tue, 18 Apr 2006 14:03:46 -0500
I am running EPICS 3.14.8.2, tornado 2.2, asyn 4.5, streamDevice 2.0 on mvme167 and ppc2304 CPUs with a serial port server.  I am able to connect to the serial devices with the generic serial record, but streamDevice gives me a connection error.  asynReport() shows the port disconnected until I connect with the generic serial record or turn on the trace masks.  Am I missing something in the initialization, or is there a problem with the code.
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 So. Cass Ave
Argonne, IL  60439 USA
Ph. (630) 252-7151
E-mail: [email protected]
IPNS website: www.pns.anl.gov
Most of boot output follows:
____________________________________________________________________________
dbLoadDatabase("$(TOP)/dbd/ancVx.dbd")
interrupt:
ei0: reset
value = 0 = 0x0
ancVx_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
# Disable Logging
iocLogDisable = 1
iocLogDisable = 0x41e738: value = 1 = 0x1
# Asyn Configuration.
drvAsynSerialPortConfigure("L0","/tyCo/1",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L7","192.168.1.251:2007",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L8","192.168.1.251:2108",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L9","192.168.1.251:2009",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L10","192.168.1.251:2010",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L11","192.168.1.251:2011",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L12","192.168.1.251:2012",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L13","192.168.1.251:2013",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L14","192.168.1.251:2014",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L15","192.168.1.251:2015",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L16","192.168.1.251:2016",0,0,0)
value = 0 = 0x0
# StreamDevice Configuration.
epicsEnvSet("STREAM_PROTOCOL_PATH", "$(TOP)/protocols")
value = 0 = 0x0
# Load EPICS Records
# Uncomment Records and change macro substitutions according to your application
dbLoadRecords("$(TOP)/db/event.db","INST=porter,NN=0,MM=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/runTime.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=0,PORT=L8")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=1,PORT=L0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/porterMotor.db")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/posChanger.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev2.db","INST=porter,MDEV=huber,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev3.db","INST=porter,MDEV=mdev,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev6.db","INST=porter,MDEV=xyz,NN=0")
value = 0 = 0x0
dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=porter:sr:")
value = 0 = 0x0
dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=porter,R=asyn,PORT=L8,ADDR=0,OMAX=0,IMAX=0")
value = 0 = 0x0
cd startup
value = 0 = 0x0
oms58Setup(6, 0x3000, 190, 5, 10)
value = 0 = 0x0
iocInit
Starting iocInit
### EPICS IOC CORE built on Mar 30 2006
### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
reboot_restore: entry for file 'pos.sav'
reboot_restore (v4.7): entry for file 'pos.sav'
reboot_restore: Found filename 'pos.sav' in restoreFileList.
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/pos.sav' at initHookState 5 ***
../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEreboot_restore: done with file 'pos.sav'
reboot_restore: entry for file 'set.sav'
reboot_restore (v4.7): entry for file 'set.sav'
reboot_restore: Found filename 'set.sav' in restoreFileList.
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/set.sav' at initHookState 5 ***
../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEreboot_restore: done with file 'set.sav'
Businterface 'L8' not found for 'porter:lksh_0:idnstrg'
porter:lksh_0:idnstrg: Can't attach to bus L8 -1
porter:lksh_0:idnstrg: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:idnstrg'
porter:lksh_1:idnstrg: Can't attach to bus L0 -1
porter:lksh_1:idnstrg: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:atype'
porter:ls330_0:atype: Can't attach to bus L8 -1
porter:ls330_0:atype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:btype'
porter:ls330_0:btype: Can't attach to bus L8 -1
porter:ls330_0:btype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:cuid'
porter:ls330_0:cuid: Can't attach to bus L8 -1
porter:ls330_0:cuid: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:atype'
porter:ls330_1:atype: Can't attach to bus L0 -1
porter:ls330_1:atype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:btype'
porter:ls330_1:btype: Can't attach to bus L0 -1
porter:ls330_1:btype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:cuid'
porter:ls330_1:cuid: Can't attach to bus L0 -1
porter:ls330_1:cuid: streamInitRecord failed
Businterface 'L8' not found for 'porter:lksh_0:rst'
porter:lksh_0:rst: Can't attach to bus L8 -1
porter:lksh_0:rst: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:rst'
porter:lksh_1:rst: Can't attach to bus L0 -1
porter:lksh_1:rst: streamInitRecord failed
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/set.sav' at initHookState 6 ***
iocInit: All initialization complete
value = 0 = 0x0
# Configure autoSave for EPICS autoSaveRestore. (task named "save_restore")
# save positions every five seconds
create_monitor_set("pos.req",5,"INST=porter")
value = 0 = 0x0
# save other things every thirty seconds
create_monitor_set("set.req",30,"INST=porter")
value = 0 = 0x0
Done executing startup script /net/iocappsDev/rporter/R3.14.8/ioc/Anc/iocBoot/iocporter-172/st.cmd
iocporter-172> ../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEporter:lksh_0:idnstrg: Record not initialised correctly
porter:lksh_1:idnstrg: Record not initialised correctly
Re: streamDevice/Asyn Error: Businterface not found Dirk Zimoch
Prev: Re: ASYN R4-5 available Dirk Zimoch
Next: RE: streamDevice/Asyn Error: Businterface not found Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: streamDevice/Asyn Error: Businterface not found Dirk Zimoch
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
