Staring at the code in .../src/dbStatic/dbLex.l and the other source
files there, I would say that escaping a double quote is supported in a
half-assed way:
\" doesn't end the string and hence is copied into the field, but no one
ever takes out the backslash. Oops. Looks like a bug to me. I created
Mantis entry 250.
Cheers,
Ralph
Rod Nussbaumer wrote:
EPICS Guruen:
I am generating EPICS .db files from a perl script, and would like to
be able to generate records which have DESC fields containing the '"'
'double-quote' character. Is this possible? What is the syntax? I have
tried editing an otherwise working database file, and have not been
able to create one that passes the database loader. Have tried using
combinations of multiple d-quotes and escaping them with various
numbers of '\' 'backslash' characters.
I am using R3.14.8.2 on Scientific Linux 4.
Thanks.
Rod Nussbaumer,
Electronics Development Group,
TRIUMF
- DESC field containing embedded double-quotes? Rod Nussbaumer
Re: ???registrar(function_name) Liyu, Andrei
<2006>
2025
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
