1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ???registrar(function_name)
To: "Liyu, Andrei" <[email protected]>
Cc: [email protected]
Date: Mon, 24 Apr 2006 14:43:20 -0500
There's a small error in the example which was attached to the original posting. The example includes a comment indicating that the command is to be invoked as:
IOCShellFunctionCall( "I am user-defined function in IOC shell")
This does not match the code in the example. In fact, the comment should state that the command is to be invoked as:
IOCShellFunction( "I am user-defined function in IOC shell")
Also, it's a good idea to include <epicsStdioRedirect.h> rather than <stdio.h> in any file which contains functions which produce output as part of an IOC shell command. This ensures that output redirection works as expected.
On Apr 24, 2006, at 2:18 PM, Liyu, Andrei wrote:
I again met this problem.
Also Geoff Savage has asked here http://www.aps.anl.gov/epics/tech- talk/2006/msg00493.php
So I created the simplest example and attach to this e-mail.
Thanks, Andrei.
P.s. Maybe someone include the example or something similar to IOC’s example.
<ExampleIOCShellFunction.c>
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Re: ???registrar(function_name) Liyu, Andrei
Prev: IOC error message - CA online suspended George Lahti
Next: RE: ???registrar(function_name) Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: ???registrar(function_name) Liyu, Andrei
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
