1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StripTool bogs down host?
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 25 Apr 2006 08:22:39 -1000 (HST)
Hi John:
We had the case of a simple medm display using all (or most of) of a Linux CPU. Running top showed that X-windows was using over 90% of the machine. It turned out we were reading in analog voltages quickly and we did not have a "minimum change before update" set in our records (I forget the mnemonic) so we were getting display updates at the full scan rate.
Craig
On Tue, 25 Apr 2006, John Dobbins wrote:
Dear All,
We've begun using StripTool and notice that is sometimes appears to bog down the computer on which it is running, i.e. the mouse responds haltingly with StripTool running, there is lag in button responses,...
This is true even if StripTool is the only app running. Host is Linux.
It seems to be made worse by making the StripTool graph display larger and helped by reducing the screen update rate.
Do others have this experience? I looked in the docs and searched Tech-Talk but didn't see anything along these lines. Is something that can be done to improve responsiveness?
John Dobbins
Laboratory for Elementary Particle Physics
Cornell University
Ithaca, NY
-- -------------------------------------------------- Craig Walther Joint Astronomy Centre [email protected] 660 N. A'ohoku Place Ph: (808) 969-6556 Hilo, HI 96720 Fx: (808) 961-6516
StripTool bogs down host? John Dobbins
Prev: Re: drvAscii decode string Maren Purves
Next: Re: No more CA connections? R3.14.7, 3.14.8.2, CAJ Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: StripTool bogs down host? John Dobbins
Next: Re: StripTool bogs down host? Chris Payne
