1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StripTool bogs down host?
To: Chris Payne <[email protected]>, John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 26 Apr 2006 17:24:01 -0400
We used to have Matrox G450 video cards with Xinerama only (6-head
display using 2 quad-head G450) and it was a lot easier to get up to
upper 90% CPU loading with StripTool chart(s) running or even to crash
the console.  Switching to nVidia video cards (GeForce FX5500, Quadro
NVS280, etc.) with a combination of twinView and Xinerama (3 twinView's)
helps to reduce the problem a lot.  The overall performance is a
combination of hardware (video card), X server, physical memory size and
display buffer size.
Also, some people want to use StripTool as archiver -- with a very large
buffer and save the buffered data to a file.  I don't think this is a
very good idea.  Maybe the default StripTool buffer size should be
smaller and have a hard limit for the buffer?
Paul
Paul C. Chu
Accelerator Physics
Spallation Neutron Source
Oak Ridge National Laboratory
-----Original Message-----
Sent: Wednesday, April 26, 2006 4:32 PM
To: John Dobbins
Cc: EPICS Tech-Talk
Subject: Re: StripTool bogs down host?
John--
We have seen response exactly like this, a relatively powerful Linux
computer
"bogged down" by a single StripTool, and it was definitely made worse by
increasing the graph window size. Our operations staff subsequently
learned
the "don't do that" rule.
Since the initial problems, we have gone through many upgrades, OS,
EPICS
base, extensions, and now I cannot seem to reproduce the problem on our
present consoles.
The problem was obvious on RedHat 7.2 with stock XFree86 and extensions
compiled against 3.13.5-ish (I think) and whatever X libraries (lesstif
maybe?) were there. Hardware was dual P3 1GHz with old ATI cards.
We are now on Scientific Linux 4.2 with stock Xorg, but an NVidia driver
for
the NVS400 cards we use. The extensions are compiled against 3.13.10,
and the
installed libraries (openmotif 2.2.3). Hardware is a P4 3.2GHz with the
NVidia card.
I think that the upgrade to the X server and new libraries are what did
it for
us, but I'm not 100% sure. How up to date are your OS and Libraries?
Cheers
Chris
Chris Payne			ISAC Operations Controls System Manager
"Relax Snap, this is particle physics, not rocket science."
On Tue, Apr 25, 2006 at 01:35:34PM -0400, John Dobbins wrote:
> We've begun using StripTool and notice that is sometimes appears to
bog
> down the computer on which it is running, i.e. the mouse responds
haltingly
> with StripTool running, there is lag in button responses,...
> This is true even if StripTool is the only app running. Host is Linux.
> It seems to be made worse by making the StripTool graph display larger
and
> helped by reducing the screen update rate.
> Do others have this experience? I looked in the docs and searched
Tech-Talk
> but didn't see anything along these lines. Is something that can be
done to
> improve responsiveness?
Prev: Re: IOC lost all comms Andrew Johnson
Next: RE: TCP/UDP port for CA Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StripTool bogs down host? Chris Payne
Next: RE: No more CA connections on different IOC Jeff Hill
