1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Digitizer needed for LCLS
To: Steve Lewis <[email protected]>
Cc: [email protected], Elden Ables <[email protected]>
Date: Tue, 02 May 2006 10:21:15 +0100
Hi Steve
Do take a look at D-TACQ ACQ196CPCI : 96 simultaneous differential channels, 16 bit resolution, one slot.
http://www.d-tacq.com/acq196cpci.shtml
The card runs Linux, has Ethernet connectivity and runs an EPICS IOC on board.
So a single card in its own private 1U chassis could meet your requirement.
Regarding your specific application, we have a burst streaming mode that will support rapid short bursts;
The EPICS IOC doesn't support this mode at the moment, but it isn't a million miles away either.
Best regards
Peter.
Steve Lewis wrote:
EPICS colleagues:
The LLNL group that is supplying the diagnostics to commission the LCLS needs a digitizer for an energy measurement instrument (calorimeter) with the following characteristics:
- 100 channels sampled simultaneously
- each channel takes 100 samples at 10us per sample (1 ms total time)
- differential inputs
- 12 bits minimum; 14 or even 16 bits preferred
- sampling repeats at 120 Hz major cycle with trigger
A VME or VXI format is ideal.
Any suggestions are most welcome. Ideally, we can discuss this in depth at the June meeting.
Peter Milne			[email protected]
D-TACQ Solutions Ltd		www.d-tacq.com
Digitizer needed for LCLS Steve Lewis
Prev: Re: Who can help with dbLoadRecords()? Benjamin Franksen
Next: Floating point exception running ArchiveEngine Michele Joyce
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Digitizer needed for LCLS Till Straumann
Next: RE: Digitizer needed for LCLS Liyu, Andrei
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
