1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer intro needed !
To: [email protected]
Date: Wed, 3 May 2006 22:28:24 +0200
On Tuesday 02 May 2006 23:05, Emmanuel Mayssat wrote:
> It seems that seq records do not like to link to records that are
> running in other IOC.
> For example, I had 2 IOCs running on the same computer at different
> ports. The seq records cannot find records in the other IOC.
> Is it expected or is my port configuration not correct?
This is definitely not expected if both IOCs have the same
EPICS_CA_SERVER_PORT (or use the default port). The links in a seq
record are regular links like any others and thus should connect via CA
if the target record.field is not on the same IOC. Are you sure the
links are not connected? How did you verify this?
Ben
RE: Sequencer intro needed ! Dalesio, Leo `Bob`
RE: Sequencer intro needed ! Emmanuel Mayssat
Prev: ISAC-II beam Rolf Keitel
Next: Power Monitoring Waggoner, Bill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Sequencer intro needed ! Emmanuel Mayssat
Next: caRepeater Al Honey
