1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MIPS epicsEventWaitWithTimeout(()
To: "'Matt Rippa'" <[email protected]>, <[email protected]>
Date: Wed, 10 May 2006 08:42:22 -0600
> Of course it would be better if we could all run the same code. :-) Maybe
> we need to disable some FPE's for the mips?
> Does EPICS rely on disabling FPE's for all tasks?
>From my perspective, it would be better to fix bugs generating FPE, and that
sweeping them under the carpet wouldn't be the better alternative.
Jeff
> -----Original Message-----
> From: Matt Rippa [mailto:[email protected]]
> Sent: Tuesday, May 09, 2006 7:49 PM
> To: [email protected]
> Subject: MIPS epicsEventWaitWithTimeout(()
> Hi all,
> We're getting a floating point exception running iocInit()
> on a mips hkbaja47 with 3.14.8.2 exampleApp. Specifically
> this is the "timerQueue" task. Tracking this down it points
> to epicsEventWaitWithTimeout() inside
> base-3.14.8.2/src/libCom/osi/os/vxWorks/osdEvent.c
> The double timeOut passed in is DBL_MAX size (1.79769e+308)
> and used to calculate a semTake timeout. Basically, semTake and wait
> a very long time:
> int ticks = timeOut*sysClkRateGet();
> status = semTake((SEM_ID)id,ticks);
> The mips can't seem to handle the double to int conversion
> and ends up with an FPE and I think it's FPE_INVALID_OP.
> It can handle this when ticks is clipped to LONG_MAX*1.0. LONG_MAX*1.1
> fails. We're wondering if there's any other gotchas if we do this for
> our mips targets?
> code. :-) Maybe we need to disable some FPE's for the mips?
> Many thanks,
> -Matt
> iocInit()
> Starting iocInit
> ###  EPICS IOC CORE built on May  8 2006
> ###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> FPE Exception
> Exception Program Counter: 0x80d3c22c
> Status Register: 0x30006701
> Cause Register: 0x0000003c
> Task: 0x80f20870 "timerQueue"
> iocInit: All initialization complete
> -> tt 0x80ac70f0
> 80024434 vxTaskEntry    +c  : epicsThreadSleepQuantum
> (&epicsThreadCallEntryPoint, 80acf48c, 0, 0)
> 808cea18 epicsThreadSleepQuantum+78 : epicsThreadCallEntryPoint (eeeeeeee,
> eeeeeeee, eeeeeeee, eeeeeeee)
> 808c2f04 epicsThreadCallEntryPoint+a4 : timerQueueActive::run(void)
> (eeeeeeee, eeeeeeee, eeeeeeee, eeeeeeee)
> 808d4ee4 timerQueueActive::run(void)+40 : epicsEvent::wait(double)
> (800cfb5c, eeeeeeee, eeeeeeee, eeeeeeee)
> 808c8804 epicsEvent::wait(double)+28 : epicsEventWaitWithTimeout
(eeeeeeee,
> 80acf494, 808c7a48, 80acfe10)
> -> ti 0x80f20870
>   NAME        ENTRY       TID    PRI   STATUS      PC       SP     ERRNO
> DELAY
> timerQueue 80d3c028     80f20870 129 SUSPEND    80d3c22c 80f205b8       0
> 0
> stack: base 0x80f20870  end 0x80f1d990  size 11840  high 1464   margin
> 10376
> options: 0xc
> VX_DEALLOC_STACK    VX_FP_TASK
> $0   =                0   at   = ffffffff80d60000   v0   =
> 3c
> v1   = ffffffff80f20870   a0   = ffffffff80f28c90   a1   =
> 0
> a2   =         7fefffff   a3   = ffffffffffffffff   t0   =
> 30006701
> t1   =         30006700   t2   =                4   t3   =
> 0
> t4   =                0   t5   =                0   t6   =
> 0
> t7   =                0   s0   = ffffffff80f28c90   s1   =
> ffffffff80f20870
> s2   = ffffffff80f28e6c   s3   = ffffffff80d34080   s4   =
> 0
> s5   =                0   s6   =                0   s7   =
> 0
> t8   =                0   t9   =                0   k0   =
> 8007823ceeeeeeee
> k1   =                0   gp   = ffffffff80119dd8   sp   =
> ffffffff80f205b8
> s8   =                0   ra   = ffffffff80d3c21c
> sr   = 30006701           pc   = 80d3c22c
> fpcsr  =  1000014
> fp0    =      Inf   fp2    =        2   fp4    = 6.31152e+08   fp6    =
> 0
> fp8    =        0   fp10   =        0   fp12   =        0   fp14   =
> 0
> fp16   =        0   fp18   =        0   fp20   = 1.79769e+308   fp22   =
> 0
> fp24   =        0   fp26   =        0   fp28   =        0   fp30   =
> 0
> FPE Exception
> Exception Program Counter: 0xvalue = 80d3c22c0
> Status Register: 0x = 0x30006701
> Cause Register: 0x00000003c
MIPS epicsEventWaitWithTimeout(() Matt Rippa
Prev: RE: MIPS epicsEventWaitWithTimeout(() Jeff Hill
Next: June EPICS Meeting reminder Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: MIPS epicsEventWaitWithTimeout(() Walters, M (Malcolm)
