1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EDM Command Options Question
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 12 May 2006 12:18:48 -0400
Hi All,
On May 5, 2006, at 12:10 PM, John Dobbins wrote:
It turn out that if I sit at the console I get the correct focus behavior. This is with Scientific Linux 3 or 4. Exceed also works for remote access. For me the problem appears to be limited to using CYGWIN for remote access.
By default, cygwin uses Windows' internal window manager, which creates a Windows window for each top-level X window. Therefore, one option is to enable "focus stealing" in Windows, which should be doable using Windows PowerTools (specifically Tweak UI):
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
The second option, which we have tested, is to tell cygwin to use an alternative window manager, such as twm, fvwm2, or mwm.
I hope someone finds this helpful,
Devin
Devin Bougie
Laboratory for Elementary-Particle Physics
[email protected]
Re: EDM Command Options Question John Dobbins
Prev: bug in break-point table conversion Rolf Keitel
Next: Re: Naming Conventions and Control Logix Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: EDM Command Options Question John Dobbins
Next: MIPS epicsEventWaitWithTimeout(() Matt Rippa
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
