1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Special characters for Stringout
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Thu, 18 May 2006 14:04:27 -0500
Emmanuel Mayssat wrote:
Hello,
I use a stingout record to write on my serial port.
The issue is that I want to write non-printable characters or Hex
values.
When in the db files I manually set field(VAL,"\x3A") (hex code for : ),
it prints \x3A... the escape sequence has not been recognized.
Is there a way to pass special characters through pao->val
If you don't find a better way of doing this, you could use an sCalcout record to encode escape sequences and send them to the stringout record. Version 2.6 of the calc module http://www.aps.anl.gov/aod/bcda/synApps/calc/calc.html includes the sCalcout record with the new functions ESC() and TR_ESC(), which translate escape sequences using, respectively, epicsStrSnPrintEscaped() and dbTranslateEscape().
For example, the string-calc expression TR_ESC("\x3a") produces the string ":"
Note that the string-calc software works with null-terminated strings, so you
cannot encode or decode \x0 with this software. For that, I would suggest
Dirk Zimoch's streamDevice
	http://epics.web.psi.ch/software/streamdevice/
or else custom device-support software.
P.S.: Be careful where you point that stingout record.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
Special characters for Stringout Emmanuel Mayssat
Prev: Special characters for Stringout Emmanuel Mayssat
Next: June Collaboration Meeting Update Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Special characters for Stringout Ralph Lange
