1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: from ihep in china
To: <[email protected]>
Cc: "tech-talk" <[email protected]>
Date: Mon, 29 May 2006 15:24:20 +0800
Hi, Carl,
I'm compiling mca in base-3.14.7, the operating system is RedHat Linux WS4(kernel is 2.6.9-22), the host-arch linux-x86 and target-arch is linux-x86, GCC 3.4.4, GNU Make 3.80, matlab 6.5, when I make according to the "README" file , there are some error like the following:
[epics@localhost mca]$ make
mex -v -I/home/epics/epics3.14.7/base-3.14.7/include -I/home/epics/epics3.14.7/b ase-3.14.7/include/os/Linux -DEPICS_DLL_NO -L/home/epics/epics3.14.7/base-3.14.7 /lib/linux-x86 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp Channe lAccess.cpp -o O.linux-x86/mca.mexglx
-> mexopts.sh sourced from directory (DIR = .)
   FILE = /home/epics/epics3.14.7/extensions/src/mca/mexopts.sh
->    MATLAB                = /home/epics/matlab
->    CC                    = gcc
->    CC flags:
         CFLAGS             = -fPIC -ansi -D_GNU_SOURCE -pthread -DGCC
         CDEBUGFLAGS        = -g
         COPTIMFLAGS        = -O -DNDEBUG
         CLIBS              = -Wl,--rpath-link,/home/epics/matlab/extern/lib/gln x86,--rpath-link,/home/epics/matlab/bin/glnx86 -L/home/epics/matlab/bin/glnx86 - lmx -lmex -lmat -lm -lm
         arguments          =  -DEPICS_DLL_NO
->    CXX                   = gcc
->    CXX flags:
         CXXFLAGS           = -fPIC -ansi -D_GNU_SOURCE -DGCC -pthread -I$EPICS_ BASE/include -I$EPICS_BASE/include/os/Linux
         CXXDEBUGFLAGS      = -g
         CXXOPTIMFLAGS      = -O -DNDEBUG
         CXXLIBS            = -Wl,--rpath-link,/home/epics/matlab/extern/lib/gln x86,--rpath-link,/home/epics/matlab/bin/glnx86 -L/home/epics/matlab/bin/glnx86 - lmx -lmex -lmat -lm -L/ade/epics/supTop/base/R3.14.2/lib/linux-x86 -lca -lCom -l readline -lcurses -losp -lrt -lm
->    FC                    =
->    FC flags:
         FFLAGS             =
         FDEBUGFLAGS        =
         FOPTIMFLAGS        =
         FLIBS              =
->    LD                    = gcc
->    Link flags:
         LDFLAGS            = -pthread -shared -Wl,--version-script,/home/epics/ matlab/extern/lib/glnx86/mexFunction.map
         LDDEBUGFLAGS       = -g
         LDOPTIMFLAGS       = -O
         LDEXTENSION        = .mexglx
         arguments          =  -L/home/epics/epics3.14.7/base-3.14.7/lib/linux-x 86 -ldbStaticHost -lCom -lca
->    LDCXX                 =
->    Link flags:
         LDCXXFLAGS         =
         LDCXXDEBUGFLAGS    =
         LDCXXOPTIMFLAGS    =
         LDCXXEXTENSION     =
-> gcc -c  -I/home/epics/epics3.14.7/base-3.14.7/include -I/home/epics/epics3.14 .7/base-3.14.7/include/os/Linux -I/home/epics/matlab/extern/include -DMATLAB_MEX _FILE -fPIC -ansi -D_GNU_SOURCE -DGCC -pthread -I$EPICS_BASE/include -I$EPICS_BA SE/include/os/Linux  -DEPICS_DLL_NO -O -DNDEBUG mca.cpp
In file included from mca.cpp:23:
queue.h: In member function `Node<T>* Node<T>::GetPrev() const':
queue.h:84: error: `Prev' undeclared (first use this function)
queue.h:84: error: (Each undeclared identifier is reported only once for each fu nction it appears in.)
queue.h: In member function `int Queue<T>::Size() const':
queue.h:123: error: there are no arguments to `Empty' that depend on a template parameter, so a declaration of `Empty' must be available
queue.h:123: error: (if you use `-fpermissive', G++ will accept your code, but a llowing the use of an undeclared name is deprecated)
queue.h:129: error: `count' undeclared (first use this function)
    mex: compile of 'mca.cpp' failed.
make: *** [O.linux-x86/mca.mexglx] Error 1
Could you help me find the reason? Thank you very much!
Zhao Zhuo
Accelerator Control Group,
Accelerator Research Center
Institute of High Energy Physics (IHEP)
P.O. Box 918-10
Beijing, 100049
P.R. China
Tel:    +86-10-88236268-11 or 88236269-11 (O)
Fax:    +86-10-88236190
E_mail: [email protected]
almost deleted message unread, was: Re: from ihep in china Maren Purves
Re: about mca (from ihep in china) Carl Lionberger
Prev: irmisBase V2.0 Claude Saunders
Next: almost deleted message unread, was: Re: from ihep in china Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
