1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynDriver / epicsTimer bug
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Tue, 30 May 2006 11:25:08 -0500
On May 30, 2006, at 11:05 AM, Dirk Zimoch wrote:
Hi Marty, Jeff et al
When asynOctet->read() (or at least readRaw() of the TCP port driver) is called on vxWorks with pasynUser->timeout < 1/ sysClkRateGet() [normally about 16 ms], the read call hangs and does never time out.
I think it is actually a problem with epicsTimer, which never expires for timeouts < 1/sysClkRateGet(). But I have not tested this.
I think, a timer should wait at least the specified amount of time, thus always round up to at least one tick.
Yes, that is what they are supposed to do. On vxWorks the code in question is:
epicsEventWaitStatus epicsEventWaitWithTimeout(
    epicsEventId id, double timeOut)
    int status;
    int ticks;
    if(timeOut<=0.0) {
        ticks = 0;
    } else {
        ticks = timeOut*sysClkRateGet();
        if(ticks<=0) ticks = 1;
    status = semTake((SEM_ID)id,ticks);
    if(status==OK) return(epicsEventWaitOK);
    if(errno==S_objLib_OBJ_TIMEOUT) return(epicsEventWaitTimeout);
    return(epicsEventWaitError);
This looks correct to me.
BTW -- the latest versions of ASYN have done away with the EPICS timers in the TCP and serial drives.
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
asynDriver / epicsTimer bug Dirk Zimoch
Prev: asynDriver / epicsTimer bug Dirk Zimoch
Next: Re: about mca (from ihep in china) Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: asynDriver / epicsTimer bug Jeff Hill
