1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Failed to install mca on WinXP
To: [email protected]
Date: Fri, 2 Jun 2006 19:43:32 +0800
Failed to install mca on WinXP. Why ?
base-3.14.7, Matlab7.0, MSVC6.0, mca3_1
mex mca.cpp MCAError.cpp Channel.cpp ChannelAccess.cpp ...
    -ID:\Tools\Epics\base-3.14.7\include ...
    -ID:\Tools\Epics\base-3.14.7\include\os\WIN32 ...
    -v
 This is mex, Copyright 1984-2003 The MathWorks, Inc.
-> Default options filename found in C:\Documents and
Settings\Administrator\Application Data\MathWorks\MATLAB\R14
->    Options file           = C:\Documents and
Settings\Administrator\Application Data\MathWorks\MATLAB\R14\mexopts.bat
      MATLAB                 = D:\Tools\Matlab
->    COMPILER               = cl
->    Compiler flags:
         COMPFLAGS           = -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo
         OPTIMFLAGS          = /MD -O2 -Oy- -DNDEBUG
         DEBUGFLAGS          = /MDd -Zi -Fd"mca.pdb"
         arguments           =  -ID:\Tools\Epics\base-3.14.7\include -
         Name switch         = /Fo
->    Pre-linking commands   =
->    LINKER                 = link
->    Link directives:
         LINKFLAGS
= /dll /export:mexFunction /MAP /LIBPATH:"D:\Tools\Matlab\extern\lib\win32
\microsoft\msvc60" libmx.lib libmex.lib libmat.lib /implib:_lib7109.x
         LINKFLAGSPOST       =
         Name directive      = /out:"mca.dll"
         File link directive =
         Lib. link directive =
         Rsp file indicator  = @
->    Resource Compiler      = rc /fo "mexversion.res"
->    Resource Linker        =
--> "cl  -ID:\Tools\Epics\base-3.14.7\include -ID:\Tools\Epics\base-3.14.7
\include\os\WIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo /Fomca.obj -
ID:\Tools\Matlab\extern\include -ID:\Tools\Matlab\simulink\include /MD -O2 -
Oy- -DNDEBUG mca.cpp"
mca.cpp
\include\os\WIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo /FoMCAError.obj -
Oy- -DNDEBUG MCAError.cpp"
MCAError.cpp
\include\os\WIN32 -c -Zp8 -G5 -W3 -DMATLAB_MEX_FILE -nologo /FoChannel.obj -
Oy- -DNDEBUG Channel.cpp"
Channel.cpp
nologo /FoChannelAccess.obj -ID:\Tools\Matlab\extern\include -
ID:\Tools\Matlab\simulink\include /MD -O2 -Oy- -DNDEBUG ChannelAccess.cpp"
ChannelAccess.cpp
    Contents of 7109_tmp.rsp:
  mca.obj  MCAError.obj  Channel.obj  ChannelAccess.obj
> "link /out:"mca.dll" /dll /export:mexFunction /MAP /LIBPATH:"D:\Tools\Matlab
\extern\lib\win32\microsoft\msvc60" libmx.lib libmex.lib
libmat.lib /implib:_lib7109.x  @7109_tmp.rsp "
Microsoft (R) Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
   Creating library _lib7109.x and object _lib7109.exp
mca.obj : error LNK2001: unresolved external symbol "__declspec(dllimport)
public: __thiscall epicsMutex::epicsMutex(void)" (__imp_??
0epicsMutex@@QAE@XZ)
public: __thiscall epicsMutex::~epicsMutex(void)" (__imp_??
1epicsMutex@@QAE@XZ)
public: void __thiscall epicsMutex::unlock(void)" (__imp_?
unlock@epicsMutex@@QAEXXZ)
public: void __thiscall epicsMutex::lock(void)" (__imp_?
mca.obj : error LNK2001: unresolved external symbol __imp__ca_pend_event@8
ChannelAccess.obj : error LNK2001: unresolved external symbol
Channel.obj : error LNK2001: unresolved external symbol __imp__ca_message@4
__imp__ca_message@4
__imp__ca_clear_channel@4
Channel.obj : error LNK2001: unresolved external symbol __imp__dbr_value_size
Channel.obj : error LNK2001: unresolved external symbol __imp__dbr_size
Channel.obj : error LNK2001: unresolved external symbol __imp__dbf_text_dim
__imp__ca_field_type@4
__imp__ca_element_count@4
Channel.obj : error LNK2001: unresolved external symbol __imp__ca_host_name@4
__imp__ca_create_channel@20
Channel.obj : error LNK2001: unresolved external symbol __imp__ca_state@4
__imp__ca_array_get@16
__imp__ca_array_put@16
__imp__ca_add_masked_array_event@52
__imp__ca_clear_event@4
__imp__ca_context_destroy@0
__imp__ca_context_create@4
__imp__ca_pend_io@8
mca.dll : fatal error LNK1120: 22 unresolved externals
  D:\TOOLS\MATLAB\BIN\WIN32\MEX.PL: Error: Link of 'mca.dll' failed.
Prev: need help btanu
Next: RE: need help Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: communications with Keithley 6485, was: Re: need help Maren Purves
Next: Re: Failed to install mca on WinXP marco_hair
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
