1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: CA communication problems
To: [email protected]
Date: Mon, 17 Jul 2006 14:08:03 +0200
Hello,
I have some problems of communication between an IOC and a client, both running on different machines on the same subnetwork on a similar environment (Epics v 13.4.7 under linux redhat 9.0 kernel 2.4.20-8).
At the beginning of the startup of the IOC, process variable values can be got without problems from a client (either a simple command line or a php script), but after a while, the data is not available any more and the following message shows up on the IOC side :
CAS: request from 192.168.101.21:55894 => "bad resource ID"
CAS: Request from 192.168.101.21:55894 => cmmd=12 cid=0xffffffff type=0 count=0 postsize=0
CAS: Request from 192.168.101.21:55894 => available=0x1 N=0 paddr=(nil)
CAS: forcing disconnect from 192.168.101.21:55894
Would someone have an idea of what's going on ?
Thanks for your help
Christophe
RE: CA communication problems Jeff Hill
Prev: Jena piezo Leicester, PJ (Pete)
Next: RE: CA communication problems Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
