Emmanuel Mayssat wrote:
Hello,
I would like to print the field name that is in the DOL.
What are all the fields for the structure pao->dol?
pao->dol.type --- ok
I could not find this information in the header file.
My understanding is that the epics database DOL are DBF_INLINK.
Where is the associated structure?
See link.h for the different structure definitions. pao->dol is a
struct link which is typedef'd to DBLINK. You should check dol.type
which for a DOL field at runtime should only ever be CONSTANT, DB_LINK
or CA_LINK, and use the appropriate member in the union value to get
the field value - you'll only need to use the constantStr or pv_link
members. If you want to see some code that does this, look at the
function dbGetString() in base/src/dbStatic/dbStaticLib.c.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
- dol->name Emmanuel Mayssat
Re: dol->name Tim Mooney
Allen-Bradley VME Scanner Module 6008 Luchini, Kristi
<2006>
2025
communication with rs485 multidrop device and command/response protocol btanu
<2006>
2025
