In my case, I use environment variable and "gmake -e" to overwrite make
variables and settings located in configure/RELEASE.
The reason I use this make option is exactly for the same purpose you
want to use it: "easy" upgrade of epics release or many builds of same
epics release.
FYI,
Emmanuel
On Fri, 2006-07-28 at 12:00 -0500, Geoff Savage wrote:
> Hi,
> When I use a new epics release I need to go into each top area,
> modify the configure/RELEASE file, do an uninstall, and then gmake.
> Are there Makefile rules available to simplify this process?
> Thanks, Geoff
- build multiple tops? Geoff Savage
Moxa N-Port, ASYN and IOC Exit John Dobbins
<2006>
2025
Re: build multiple tops? Andrew Johnson
<2006>
2025
