1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Smooth transition from medm to edm
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 11 Aug 2006 09:45:36 +0200
Emmanuel,
Jefferson Lab (in close cooperation with the edm authors) developed an adl-to-edl (medm-to-edm) converter. This tool can be used as a filter on the edm command line, i.e. medm files are converted on-the-fly and handed to edm for display.
Find the tool on the edm home page at http://ics-web1.sns.ornl.gov/edm/ - good luck!
Hope this helps,
Ralph
Emmanuel Mayssat wrote:
Hello,
Is it possible to smoothly more from medm to edm (i.e. open edm displays from medm, or medm displays from edm)?
or do I have to convert all of my display files at once ?
Smooth transition from medm to edm Emmanuel Mayssat
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Next: Porting EPICS to NetBSD David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Smooth transition from medm to edm Emmanuel Mayssat
Next: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
