1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Original Motorola MVME 167 PROM
To: Steven Hartman <[email protected]>
Cc: Jiro Fujita <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 17 Aug 2006 13:31:41 -0400
Here is what you need
line 1:4379C02B
line 2:04/27/94
line 3:167 U1 or 167 U2.
You need both U1 and U2.
I have a bunch of sets. I can send you a set if you need them.
Brad Cumbia Accelerator Network Administrator/Senior Controls Technologist Thomas Jefferson National Accelerator Facility Electrical Engineering Support Group Instrumentation & Control Systems Accelerator Computing Environment 12000 Jefferson Avenue Newport News, Virginia 23606 Phone (757)269-5839 Pager (757)584-5839 Fax (757)269-7309 ____ __ ___ / / // \/ _ \ __/ / // - / _ / /___/___/._/_.__/ ================================================= () ------------------------------------------------ ||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO| ||* * * * * * * * * * :::::::::::::::::::::::::| ||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO| ||* * * * * * * * * * :::::::::::::::::::::::::| ||* * * * * * * * * * OOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||:::::::::::::::::::::::::::::::::::::::::::::| ||OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO| ||---------------------------------------------- || || || ||
Steven Hartman wrote:
one, I can't tell if this is it or not.  On the PROM itself, it says
"MVME 167 U2 5.02b".  Does anybody have one that you can check with??
If I recall correctly, the U2 chip you have is an old VxWorks PROM
(version 5.02b), not the Motorola one.
Re: Original Motorola MVME 167 PROM Jiro Fujita
RE: Original Motorola MVME 167 PROM Hammonds, John P.
RE: Original Motorola MVME 167 PROM Steven Hartman
Prev: RE: Original Motorola MVME 167 PROM Steven Hartman
Next: MVME5500/Kate Feng wrote : > Anyway, the reason why I wanted to > clarify is that there is a cavet about the MVME5500 board, which is > due to its Discovery I system controller. It is a different issue fromwhat was discussed about the dummy read. > * Some PCI devices require Synchronization Barriers or PCI ordering > * for . For example, the VME-OMS58 motor controller we > * used at NSLS requires either enhanced CPU Synchronization Barrier > * or PCI-ordering (only one mechanism is allowed) for the PCI-write. > * The PCI-ordering simply implements a PCI conMVME5500/100 PCI sync. (was Re: Dev lib off-board register access) Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Original Motorola MVME 167 PROM Jiro Fujita
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
