Subject: |
Re: MVME5500/Kate Feng wrote : > Anyway, the reason why I wanted to > clarify is that there is a cavet about the MVME5500 board, which is > due to its Discovery I system controller. It is a different issue fromwhat was discussed about the dummy read. > * Some PCI devices require Synchronization Barriers or PCI ordering > * for . For example, the VME-OMS58 motor controller we > * used at NSLS requires either enhanced CPU Synchronization Barrier > * or PCI-oMVME5500/100 PCI sync. (was Re: Dev lib off-board register access) |
Kate Feng <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 17 Aug 2006 13:59:26 -0400 |
Recall for the "Subject"
I apologize for the subject I sent in my previous E-mail due to the
"cut and paste" error. -- Kate
Kate Feng wrote:
> FYI : In past July, I posted :
> http://www.aps.anl.gov/epics/tech-talk/2006/msg00820.php
> The PCI synchronization is required for some PCI or VME
> devices ( e.g. only VME-OMS58 motor controller is needed in our
> application) to function properly on not only the MVME5500
> but also the 6100. The implementation on the MVME5500,
> is different from the one in the MVME6100 (I do'nt have
> the 6100). The solution I mentioned in the pci/pci_interface.c
> (attached) has to be implemented at the MVME5500 BSP level
> when the PCI bus is initilaized. In other words, vxWorks has to
> provide the interface (or an option) in the MVME5500 or 6100 BSP.
> At the user level application, the pciToCpuSync(0) is required
> following each register write.
> Regards,
> Kate
> /* pci_interface.c
> * Copyright 2004, 2006, All rights reserved including its function.
> * Brookhaven National Laboratory and Shuchen Kate Feng <[email protected]>
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution.
> * 8/17/2006 : S. Kate Feng
> * uses in_le32()/out_le32(), instead of inl()/outl() so that
> * it is easier to be ported.
> #include <libcpu/io.h>
> #include <rtems/bspIo.h> /* printk */
> #include <bsp.h>
> #include <bsp/pci.h>
> #include <bsp/gtreg.h>
> #include <bsp/gtpcireg.h>
> #define REG32_READ(reg) in_le32((volatile unsigned int *)(GT64260_REG_BASE+reg))
> #define REG32_WRITE(data, reg) out_le32((volatile unsigned int *)(GT64260_REG_BASE+reg), data)
> #define PCI_DEBUG 0
> /* Please reference the GT64260B datasheet, for the PCI interface,
> * Synchronization Barriers and PCI ordering.
> * for synchronization. For example, the VME-OMS58 motor controller we
> * or PCI-ordering (only one mechanism allowed. See section 11.1.2).
> * To use the former mechanism(default), one needs to call
> * CPU0_PciEnhanceSync() or CPU1_PciEnhanceSync() to perform software
> * synchronization between the CPU and PCI activities.
> * To use the PCI-ordering, one can call pciToCpuSync() to trigger
> * the PCI-to-CPU sync barrier after the out_xx(). In this mode,
> * PCI configuration reads suffer sync barrier latency. Please reference
> * the datasheet to explore other options.
> * Note : If PCI_ORDERING is needed for the PCI0, while disabling the
> * deadlock for the PCI0, one should keep the CommDLEn bit enabled
> * for the deadlock mechanism so that the 10/100 MB ethernet will
> * function correctly.
> #define PCI_ORDERING
> /*#define PCI_DEADLOCK*/
> /* So far, I do not see the need to disable the address pipelining.
> #define DIS_ADDR_PIPELINE*/
> #ifdef PCI_ORDERING
> #define PCI_ACCCTLBASEL_VALUE 0x01009000
> #else
> #define PCI_ACCCTLBASEL_VALUE 0x01001000
> #endif
> #define ConfSBDis 0x10000000 /* 1: disable, 0: enable */
> #define IOSBDis 0x20000000 /* 1: disable, 0: enable */
> #define ConfIOSBDis 0x30000000
> #define CpuPipeline 0x00002000 /* optional, 1:enable, 0:disable */
> #define CPU0_SYNC_TRIGGER 0xD0 /* CPU0 Sync Barrier trigger */
> #define CPU0_SYNC_VIRTUAL 0xC0 /* CPU0 Sync Barrier Virtual */
> #define CPU1_SYNC_TRIGGER 0xD8 /* CPU1 Sync Barrier trigger */
> #define CPU1_SYNC_VIRTUAL 0xC8 /* CPU1 Sync Barrier Virtual */
> /* CPU to PCI ordering register */
> #define DLOCK_ORDER_REG 0x2D0 /* Deadlock and Ordering register */
> #define PCI0OrEn 0x00000001
> #define PCI1OrEn 0x00000020
> #define PCIOrEn 0x40000000
> #define PCIOrEnMASK 0x40000021
> #define CNT_SYNC_REG 0x2E0 /* Counters and Sync Barrier register */
> #define L0SyncBar 0x00001000
> #define L1SyncBar 0x00002000
> #define DSyncBar 0x00004000
> #define SyncBarMode 0x00008000
> #define SyncBarMASK 0x0000f000
> #define WRTBK_PRIO_BUFFER 0x2d8 /* writback priority and buffer depth */
> #define ADDR_PIPELINE 0x00020000
> void pciAccessInit();
> void pci_interface()
> unsigned int data;
> #if (defined(PCI_ORDERING)||defined(DIS_ADDR_PIPELINE))
> data = REG32_READ(0); /* needed : read to flush */
> /* MOTLOad default disables Configuration and I/O Read Sync Barrier
> * which is needed for enhanced CPU sync. barrier */
> #ifdef PCI_ORDERING
> /* enable Configuration Read Sync Barrier and IO read Sync Barrier*/
> data &= ~ConfIOSBDis;
> #endif
> #ifdef DIS_ADDR_PIPELINE
> data &= ~ADDR_PIPELINE;
> #if PCI_DEBUG
> printk("data %x\n", data);
> #endif
> #endif
> REG32_WRITE(data, 0);
> /* read polling of the register until the new data is being read */
> while ( REG32_READ(0)!=data);
> #endif
> #ifdef PCI_DEADLOCK
> REG32_WRITE(0x07fff600, CNT_SYNC_REG);
> #endif
> #ifdef PCI_ORDERING
> REG32_WRITE(0xc0060002, DLOCK_ORDER_REG);
> #else
> REG32_WRITE(REG32_READ(PCI0_CMD_CNTL)|PCI_COMMAND_SB_DIS, PCI0_CMD_CNTL);
> #endif
> /* asserts SERR upon various detection */
> REG32_WRITE(0x3fffff, 0xc28);
> pciAccessInit();
> /* Use MOTLoad default for Writeback Priority and Buffer Depth
> unsigned int PciLocal, data;
> for (PciLocal=0; PciLocal < 2; PciLocal++) {
> /* MOTLoad combines the two banks of SDRAM into
> * one PCI access control because the top = 0x1ff
> data = REG32_READ(GT_SCS0_Low_Decode) & 0xfff;
> data |= PCI_ACCCTLBASEL_VALUE;
> data &= ~0x300000;
> REG32_WRITE(data, PCI0_ACCESS_CNTL_BASE0_LOW+(PciLocal * 0x80));
> #if PCI_DEBUG
> printk("PCI%d_ACCESS_CNTL_BASE0_LOW 0x%x\n",PciLocal,REG32_READ(PCI_ACCESS_CNTL_BASE0_LOW+(PciLocal * 0x80)));
> #endif
> /* Sync Barrier Trigger. A write to the CPU_SYNC_TRIGGER register triggers
> * the sync barrier process. The three bits, define which buffers should
> * be flushed.
> * Bit 0 = PCI0 slave write buffer.
> * Bit 1 = PCI1 slave write buffer.
> * Bit 2 = SDRAM snoop queue.
> void CPU0_PciEnhanceSync(unsigned int syncVal)
> REG32_WRITE(syncVal,CPU0_SYNC_TRIGGER);
> while (REG32_READ(CPU0_SYNC_VIRTUAL));
> void CPU1_PciEnhanceSync(unsigned int syncVal)
> REG32_WRITE(syncVal,CPU1_SYNC_TRIGGER);
> while (REG32_READ(CPU1_SYNC_VIRTUAL));
> /* Currently, if PCI_ordering is used for synchronization, configuration
> * reads is programmed to be the PCI slave "synchronization barrier"
> * cycles.
> void pciToCpuSync(int pci_num)
> unsigned char data;
> unsigned char bus=0;
> if (pci_num) bus += BSP_MAX_PCI_BUS_ON_PCI0;
> pci_read_config_byte(bus,0,0,4, &data);
- MVME5500/Kate Feng wrote : > Anyway, the reason why I wanted to > clarify is that there is a cavet about the MVME5500 board, which is > due to its Discovery I system controller. It is a different issue fromwhat was discussed about the dummy read. > * Some PCI devices require Synchronization Barriers or PCI ordering > * for . For example, the VME-OMS58 motor controller we > * used at NSLS requires either enhanced CPU Synchronization Barrier > * or PCI-ordering (only one mechanism is allowed) for the PCI-write. > * The PCI-ordering simply implements a PCI conMVME5500/100 PCI sync. (was Re: Dev lib off-board register access) Kate Feng
MVME5500/6100 PCI sync (was Re: Dev lib off-board register access) Kate Feng
<2006>
2025
<2006>
2025
