1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VCCT and CA sniffer
To: Chris Payne <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 24 Aug 2006 10:52:28 +0200
Chris,
However, in the ISAC Controls system at TRIUMF we use non-standard ports for the main ISAC Control system. Beyond that we also use different ports from our main, non-standard ports for some of the secondary systems (yes, it
can get confusing).
We could implement the Ethereal decoder in such a way that the user would set a list of port numbers for the CA protocol in case non-default ports are in use.
Since different port numbers typically designate different systems, it might also make sense to give human-readable names to these ports, and show this text as a special field, which could then also be used for filtering, searching and in packet info display.
The reasons for these non-standard ports aside, I have a question about how the CA packets will be recognized. Will it be purely based on source/destination port, or some other header in the packet? If it will be based solely on ports, do you foresee the ability to customize the ports associated with the CA protocol in the proposed CA ethereal plug-in?
CA packets can not be reliably identified by other means than by port numbers (e.g., they don't contain magic codes or anything of the sort). As said above, the port numbers would thus be customizable to cover your case.
As a side note, do other labs use non-standard CA ports, or are we on our own
here?
At Cosylab we also use non-default ports to ensure isolation of systems.
Cheers,
Rok
Re: VCCT and CA sniffer Ned Arnold
Re: VCCT and CA sniffer Matt Bickley
Re: VCCT and CA sniffer Ernest L. Williams Jr.
Re: VCCT and CA sniffer Matthieu Bec
Re: VCCT and CA sniffer Rok Sabjan
Re: VCCT and CA sniffer Chris Payne
Prev: Re: EPICS driver support for Oxford Cryosystems 700 Series Cryostream David Maden
Next: ezca and ENUM D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VCCT and CA sniffer Emmanuel Mayssat
Next: Re: VCCT and CA sniffer Rolf Keitel
