1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: NetBSD: looks like it running properly. Now for a Display Manager
To: <[email protected]>
Date: Thu, 24 Aug 2006 15:05:29 -0500
Looks like the NetBSD port of EPICS is working properly.  At least, all the commands in Chapter 9 now seem to work, as well as the example program, and the caClient program.
I'm going to get the regression test from the website next, and really mess things up.
Question:  I'd like to install a display Manager now, so I can setup some really basic displays of variable data.  From looking through stuff, I think I want to install EDM.  Any suggestions?
Looking through the install instructions on several of these, I keep seeing references to an "Extensions" directory.  Is there a specific place things like the sequencer and display managers and drivers need to be untar'd to in order to build correctly?
Still being a pest.....
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" David Dudley
Next: Ethereal => Wireshark Andrew Johnson
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
