1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: OSI Replacement for rebootHookAdd ???
To: EPICS tech-talk <[email protected]>
Date: Thu, 31 Aug 2006 16:37:19 -0600
Greetings all.
A number of my drivers (and others as well) call the vxWorks routine "rebootHookAdd" -- mostly to install rundown routines that will disable the card's interrupts in the event of a soft reboot. Since I seem to be into portability these days, it would be nice to have an OSI equivalent function.
epicsAtExit seems to be the logical candidate, and there is even a hook in the vxWorks part of libCom/osi/os (atReboot.cpp) that will invoke epicsExitCallAtExits() during a soft reboot. The catch, however, is that you need to have (as I understand it) a routine called "sysAtReboot" built into your BSP for the exit handler to be called on a soft reboot. sysAtReboot (again, as I understand it) is an APS BSP extension that solves the problem of rebootHooks not invoking its exit handlers in the correct order.
So, with the above history out of the way (and feel free to comment on the authenticity of the above), my (perhaps) naive questions are:
1. How does RTEMS solve the soft reboot handler problem (I don't see any similar hook in libCom/osi/os/RTEMS)?
2. Would it be reasonable for the vxWorks hook (atReboot.cpp) to register with rebootHookAdd if it did not find sysAtReboot in the symbol table? (at least then I could get my cards disabled -- and I don't really care about the order).
3. Is there some other mechanism I should be using that I've overlooked?
Thanks.
-Eric Bj.
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031 email: [email protected]
TSPA :: DUSA=ADTO
Re: OSI Replacement for rebootHookAdd ??? Eric Norum
Re: OSI Replacement for rebootHookAdd ??? Andrew Johnson
Prev: Re: Fedora Core 6 to drop OpenMotif Benjamin Franksen
Next: Re: Fedora Core 6 to drop OpenMotif Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: EPICS in VMEbus Systems magazine! Lawrence T. Hoff
Next: Re: OSI Replacement for rebootHookAdd ??? Eric Norum
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
