1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Device with INP as a PV_LINK
To: Tim Mooney <[email protected]>
Cc: Emmanuel Mayssat <[email protected]>, epics <[email protected]>
Date: Wed, 06 Sep 2006 09:31:59 -0500
Tim Mooney wrote:
By the way, you example problem is treated in Ned Arnold's devTimeOfDay.c. I snuck a copy of this into the synApps std module, if you're interested.
These old timestamp conversion device supports are no longer needed, and should be eliminated - since R3.14.5 there has been a soft stringin device support included with Base called devTimestampSI.c whose INST_IO parm string is a format string for epicsTimeToStrftime() which extends the strftime() formatting to include fractional seconds.
The time value that this device support converts is the timestamp of the stringin record itself, but by pointing its .TSEL field to another record's .TIME field it can be made to convert arbitrary timestamps by reading them from that other record. If the time you want to convert isn't in any record's timestamp yet, you can make it one using a subroutine record whose subroutine sets its own timestamp by converting it from whatever format you do have (the sub record will need to have its .TSE field set to -2 to stop it from being overwritten by the record support afterwards).
Here are a couple of examples, untested.
# timeString gives the timestamp from timeMe
record(bi, "timeMe") {
  field(SCAN, "I/O Intr")
  field(FLNK, "timeString")
record(stringin, "timeString") {
  field(TSEL, "timeMe.TIME")
  field(DTYP, "Soft Timestamp")
  field(INP, "@%Y-%m-%d %H:%M:%S.%9f")
# Offset timestamp record(sub, "drWho") { field(TSE, "-2") field(SNAM, "timeTravel") field(INPA, "10") } record(stringin, "timeString") { field(TSEL, "delayedTime.TIME") field(DTYP, "Soft Timestamp") field(INP, "@%Y-%m-%d %H:%M:%S.%9f") }
static long timeTravel(subRecord *precord)
    epicsTimeGetCurrent(&precord->time);
    epicsTimeAddSeconds(&precord->time, precord->a)
    return 0;
If somebody wants to test the above and post any corrections this message can act as an example to future questioners on the topic.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: Device with INP as a PV_LINK Eric Norum
Device with INP as a PV_LINK Emmanuel Mayssat
Re: Device with INP as a PV_LINK Tim Mooney
Prev: Re: StripTool2_5_10_0 display of waveform records? Thomas Pelaia II
Next: Re: A question concerning rset->special() Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Device with INP as a PV_LINK Tim Mooney
Next: Re: Device with INP as a PV_LINK Eric Norum
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
