1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ioc log client cpu consumption
To: "'Jeff Hill'" <[email protected]>, "'Andrew Johnson'" <[email protected]>, "'Gasper Jansa'" <[email protected]>
Cc: "'Tech Talk'" <[email protected]>
Date: Mon, 11 Sep 2006 18:22:18 -0600
I committed a fix to R3.14 and also the main trunk for this problem (mantis
269). It turns out that there have been a number of different authors
working on this source recently. There was a race condition where the thread
responsible for reconnects was setting its own "block until there is work to
do" semaphore. It was doing this whenever there was a connect attempt
failure, and was consequently chasing its tail.
Jeff
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Monday, September 11, 2006 11:40 AM
> To: 'Andrew Johnson'; 'Gasper Jansa'
> Cc: 'Tech Talk'
> Subject: RE: IocLogInit pu consumption (who to blame)
> > Do any of the other EPICS core developers claim ownership of the
> > src/libCom/logClient/logClient.c code, which is where the problem lies?
> I will claim responsibility.
> I created Mantis entry 269.
> Typically, the socket connect system call will block the calling thread
> should the connect attempt be unsuccessful, but apparently if there are no
> local routing options the call fails out immediately (without suspending
> the
> thread for any amount of time) opening up a CPU consumption vulnerability
> because the code as written attempts to connect again immediately. The fix
> will probably be a delay inserted where the socket connect attempt fails
> (prior to rejoining the loop sustaining the connection attempts).
> Thanks for reporting the bug.
> Jeff
> > From: Andrew Johnson [mailto:[email protected]]
> > Sent: Monday, September 11, 2006 10:23 AM
> > To: Gasper Jansa
> > Cc: Tech Talk
> > Subject: Re: IocLogInit
> > Gasper Jansa wrote:
> > > I have noticed that if I set EPICS_IOC_LOG_INET to lets say
> 10.17.10.241
> > and if
> > > I am on a network from which this IP can not be reached cpu goes to
> 100%
> > and
> > > stays there if I start logging with command iocLogInit from startup
> > script. I
> > > also get "Network unreachable" error.
> > > I am experiencing this on a debian and scientific linux.
> > After a little investigation I can replicate your problem on FC4, and I
> > see that this behaviour of the log client is different if you have a
> > default route set on the machine (which is probably how most developer
> > linux workstations are configured).
> > With no default route (no line for the destination 0.0.0.0 in the output
> > from 'netstat -nr') I get your behaviour:
> > > epics> epicsEnvSet EPICS_IOC_LOG_INET 192.168.123.45
> > > epics> iocLogInit
> > > log client: unable to connect to "192.168.123.45:7004" because
> > 101="Network is unreachable"
> > > log client: unable to connect to "192.168.123.45:7004" for 2.0 seconds
> > > epics> iocLogShow
> > > log client: disconnected from log server at "192.168.123.45:7004"
> > The CPU usage on the machine then pegs at 100%.
> > However, with a default route installed (a destination of 0.0.0.0 listed
> > in the output from 'netstat -nr') I get this instead:
> > > epics> iocLogInit
> > > epics> iocLogShow
> > After a while I also get this message:
> > 110="Connection timed out"
> > The machine CPU usage remains normal in this case.
> > I would therefore recommend that you set a default route on your IOC
> > machine as a workaround until we get a fix into Base.
> > The iocLogShow command I used above is not callable from the iocsh in
> > any released version of Base; I just added the relevent iocsh table
> > entries that make it callable and committed the changes to CVS.
> >   The 101 value above would appear to be ENETUNREACH which is not
> > mentioned in any osdSock.h file and not expected by the code in
> > logClientConnect().  I might expect similar kinds of problems to appear
> > if someone mentions an unreachable IP address in any of the network
> > configuration settings such as EPICS_CA_ADDR_LIST, but I haven't tried
> > them to confirm that.
> > - Andrew
> > There is considerable overlap between the intelligence of the smartest
> > bears and the dumbest tourists -- Yosemite National Park Ranger
Prev: RE: IocLogInit pu consumption (who to blame) Jeff Hill
Next: Failure to build EPICS 3.14.8.2 on Windows XP using VC++ 2005 Express Edition Alan Greer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
