1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Active-X and Epics
To: tech talk <[email protected]>
Date: Fri, 15 Sep 2006 16:22:28 -0400
On Sep 15, 2006, at 15:56 , Bill Nolan wrote:
Hi all,
It looks like I am going to have to connect a number of devices in
to my system that only offer active-X hooks.
I have two device types with widows control software that offer
Active-X interfaces, the remainder of my controls are Epics on Linux hosts.
Is the Active_X interface form the CA_interfaces page still the best way
to approach getting the two systems to talk ?
In case you're referring to the ActiveX CA server & client stuff that
one can still get from http://ics-web1.sns.ornl.gov/~kasemir/axca/ index.html :
Bad idea. It was primarily developed to allow Labview to serve
data via Channel Access, but for LabView there are now better
solutions, so this has not been maintained for years.
Besides, if you wanted to use _that_ to connect your ActiveX stuff
to EPICS, it would mean:
You write a gateway program in for example Visual Basic that uses the Active X
controls that you got for your devices and passes data back and forth
between them and the Active X CA server or client.
Would making a soft IOC and linking the vendor supplied Active X/dll's
in to sub() records be a better way to go ?
Yes, that would be a much more direct way to get from an IOC database
to your devices. And I agree with Mark that writing 'proper' device support
is probably better than routines for sub-records, unless this is only
a 'one-of' thing that you need to handle.
-Kay
Active-X and Epics Bill Nolan
Prev: RE: Active-X and Epics Mark Rivers
Next: RE: Active-X and Epics Munro Jr, John K.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
