1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Epics 3.14.8.2 for Windows still has problems
To: EPICS tech-talk <[email protected]>
Date: Mon, 18 Sep 2006 15:05:19 -0400
I have loaded and tried to build Epics 3.14.8.2 on Windows OS with VC++ (VC++ 7.0 in VS2003) and gnu make 3.80.0-3 (mingv).
I found that
- still there is com.dll issue ( http://www.aps.anl.gov/epics/tech-talk/2006/msg00323.php ) - thank you Dale
Then I tried to build test IOC and met the same problem as was noticed here
http://www.aps.anl.gov/epics/tech-talk/2006/msg00065.php
Usage of “–b <epics_Base>” doesn’t help.
Can anyone fix first issue and help with second?
Thanks, Andrei.
Prev: RE: alternative approach to measuring a time delay Jeff Hill
Next: Re: RE: Channel archiver r_ani
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
