At our infrastructure monitoring system we have the case that some temperature values should trigger an alarm only if they remain above/below a threshold (HIHI/LOLO) for longer than a defined amount of time. As we could not find support for this feature in the documentation, we would be glad to receive a suggestion regarding a solution or implementation we could go for. The involved sensor devices are represented by "ai" records with a home-made device implementation. We use EPICS release 3.14 on Linux. Many thanks in advance! Bernhard.
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
