On Mon, 2006-09-25 at 15:25 -0400, Liyu, Andrei wrote:
> Ernest Williams found way to work with Windows/CMD(not cygwin)/VC++ 8.0/Epics 3.14.8.2. I have tested with Windows/CMD(not cygwin)/VC++ 7.0/Epics 3.14.8.2.
Actually, Janet Anderson helped me get this working.
> 1. Simple "makeBaseApp.pl -t example example" doesn't work.
> 2. "makeBaseApp.pl -b <EpicsBase> -t example example" doesn't work.
> 3. "makeBaseApp.pl -T <EpicsTemplate> -t example example" doesn't work.
> But "makeBaseApp.pl -b c:\epics\base -T c:\epics\base\templates\makeBaseApp\top -t example example" does work.
> Please, fix that.
> Thanks, Andrei.
> C:\testioc>makeBaseApp.pl -T c:\epics\base\templates\makeBaseApp\top -t example example
> Can't find EPICS base
> C:\testioc>makeBaseApp.pl -b c:\epics\base -T c:\epics\base\templates\makeBaseAp
> C:\testioc>dir
> Volume in drive C has no label.
> Volume Serial Number is E886-E139
> Directory of C:\testioc
> 09/25/2006 03:09 PM <DIR> .
> 09/25/2006 03:09 PM <DIR> ..
> 09/25/2006 03:09 PM <DIR> configure
> 09/25/2006 03:09 PM <DIR> exampleApp
> 09/25/2006 03:09 PM 400 Makefile
> 1 File(s) 400 bytes
> 4 Dir(s) 22,654,251,008 bytes free
> C:\testioc>makeBaseApp.pl -b c:\epics\base -T c:\epics\base\templates\makeBaseApp\top -i -t example example
> Using target architecture win32-x86 (only one available)
> The following applications are available:
> example
> What application should the IOC(s) boot?
> The default uses the IOC's name, even if not listed above.
> Application name? example
> C:\testioc>
> From: Jeff Hill [mailto:[email protected]]
> Sent: Monday, September 18, 2006 4:25 PM
> To: Liyu, Andrei
> Cc: EPICS-tech-talk
> Subject: RE: Epics 3.14.8.2 for Windows still has problems
> Andrei,
> I don't appear to be experiencing either of these two problems.
> > http://www.aps.anl.gov/epics/tech-talk/2006/msg00323.php
> I am using cygwin gnu make 3.80 w/o issues. Is this a problem with a mingw gnu make or is it a problem with using bash to build the system for win32-x86 (on windows I am building using the windows supplied dos shell). On my system mingw does not include a gnu make binary, but I might have an older version of mingw.
> > http://www.aps.anl.gov/epics/tech-talk/2006/msg00065.php
> I am creating my application (and specifying the path to base) like this, and building the application w/o issues.
> >perl ..\base\bin\win32-x86\makeBaseApp.pl -i -t example ex
> >perl ..\base\bin\win32-x86\makeBaseApp.pl -t example ex
> Is this really an issue with the -b option for makeBaseApp on windows?
> Jeff
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Monday, September 18, 2006 1:05 PM
> To: EPICS tech-talk
> Subject: Epics 3.14.8.2 for Windows still has problems
> I have loaded and tried to build Epics 3.14.8.2 on Windows OS with VC++ (VC++ 7.0 in VS2003) and gnu make 3.80.0-3 (mingv).
> I found that
> - still there is com.dll issue ( http://www.aps.anl.gov/epics/tech-talk/2006/msg00323.php ) - thank you Dale
> Then I tried to build test IOC and met the same problem as was noticed here
> Usage of "-b <epics_Base>" doesn't help.
> Can anyone fix first issue and help with second?
> Thanks, Andrei.
- RE: Epics 3.14.8.2 for Windows still has problems Liyu, Andrei
RE: Experience with CAJ Jeff Hill
<2006>
2025
Re: Epics 3.14.8.2 for Windows still has problems Ralph Lange
<2006>
2025
