1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Setting MEDM window title
To: Simon Rees <[email protected]>
Cc: [email protected]
Date: Mon, 16 Oct 2006 11:11:06 -0700
I am not sure if xprop works on solaris.
But xprop is part of X, and will only work if the medm window is ALREADY
open. That is if you enter the medm command and the xprop right after,
the xprop will not work because the adl file is not yet open.
So you may need to use the sleep command.
An alternative is to soft link the adl file and open that new file.
Those are the only 2 solutions I have found. In that latter case, you
cannot get rid of the adl extension.
Annoying huh?
Emmanuel
On Mon, 2006-10-16 at 18:50 +0100, Simon Rees wrote:
>    c) looked at a previous solution described in tech talk here:
>       http://www.aps.anl.gov/epics/tech-talk/2006/msg00884.php
> Unfortunately the solution described in (c) only seems to
> be supported under linux (xprop -set doesn't work on our Solaris
> platform).
Setting MEDM window title Simon Rees
Prev: Setting MEDM window title Simon Rees
Next: WARNING NOTIFICATION From Argonne Credit Union REF-ID #86153 Argonne Credit Union
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
